Why aren't there PAPER dome tweeters?
I believe Acoustic Research originally used 0.75" paper dome tweeters in their AR-3, AR-2a, & AR-2ax models.
Strictly speaking, they were 'phenolic' domes.
https://en.wikipedia.org/wiki/Phenolic_paper
Reactions: JMFahey and GM
A textile material has a more open weave than paper, and it is into the openings in the weave that the stiffening substance permeates.
The result is a combination of lightness and stiffness that likely cannot be achieved with paper and an external coating.
Early Acoustic Research tweeter domes were phenolic-treated cotton fabric, which transitioned to paper with the AR-3a. The AR-4x used a paper cone.
https://audioxpress.com/article/speakers-parts-is-parts-tweeter-history-cones-and-domes
That article reminded me that in the 1970s, the paper cone CTS tweeter was ubiquitous, used in countless two-way designs from Acoustic Research, Altec, Marantz, RadioShack, Rectilinear, and most of us DIY types around back then, arguably the most used tweeter of all time:
There are still tons of new and used cabinets using similar paper cone tweeters.
why not cone paper tweeter...
There are a few of those around which can come in quite handy for vintage loudspeaker renovations.
For example: https://www.monacor.com/products/components/speaker-technology/hi-fi-tweeters-/ht-22-8/
And: https://www.visaton.de/en/products/drivers-accessories/cone-tweeters
Here's a recent discussion on cone tweeters: https://www.diyaudio.com/community/threads/why-arent-there-any-great-cone-tweeters.393952/
Early Acoustic Research tweeter domes...
Thanks, I too discovered that article after making my initial post.
This phenolic tweeter were indeed a popular tweeter which clearly satisfied consumers for decades.
I've used them as replacements, and new builds, and I can honestly say that even today I'm amazed at their clarity and smooth response.
The only thing I have to say is that the hollow rivet you see between the terminals needs to be sealed with a drop of epoxy - to keep from whistling, particularly if used in an closed/air-supension system.
Parts Express has these at a very reasonable price.
Reactions: Pano
Those phenolic ring tweeters were ubiquitous in the 70s and 80s because they were cheap and they did the job. Most had small voice coils limiting power handling and a very high Fs limiting frequency range on the low end. Most had crappy 6db single cap cross overs too. The reason paper is not popular for dome tweeters are many. Weight for needed stiffness, ease of permanent damage from being poked, etc.. Once the Peerless KO10DT appeared they went out of style.
