where I took of the front, so that the dome is all the way into the mounting hole..... still the same....😕This WG-300 looks alot like my measurement of the WG148R:
Test Monacor DT-300 with Waveguide WG-300 AutoClicker
Seas DXT just looks way more smooth:
Test report | Seas DXT 27TBCD / GB (H1499-06)
And if I should get tired of my Accuton - I could easily pair the DXT with a L12/15 or W12//15. I do run 4 ways fully active and use 3x18W scanspeak classics for midbass. So integration should be possible.... hmm... many things to test 😛
Better listen a bit to music and think later 😀
An old SB25 - but could 1mm less in diameter do so much?
Wow the Peerless Peerless DA25TX00-08 looks like a knock-off of the SEAS E0047-04 T29MF001.
It's more similar to the TLabs N26CR2.
Wolf
Wolf
In terms of looks, performance or both?
Also, what are your thoughts regarding DA25TX vs. SB26CDC?
Performance and looks. Eugen of TL even called it a TL knockoff himself. I'm not opposed to either, and really like ceramic tweeters. The Peerless is more analytical in sound, but I like both.
Later,
Wolf
Later,
Wolf
The peerless unit is totally different to the Seas tweeter,
No 'moderate horn loading' on the peerless.
The Seas has neo motor system, different coil lengths, different dome material and a very different frequency response.
As for the TL claims, they are ludicrous, there is nothing to back up those..
Compare the spec sheets, big differences in every major component, spec and design approach,
In fact the only similarities if you look for them are that they are both hard dome with low fs and 90ish dB sensitivity,
The TL shares more in common with the Seas..
Have been looking at the DA32TX00-08 for some time.
Sd on 12 cm2 and Xmax of 1 mm, should make for a very low crossover.
Have tried to ask Tymphany if the Xmax is pp or one way .... no answer .... anyone knows??
I would like to use a 7" waveguide and crossover to either a 18 Sound 6ND430
or SATORI MW19P-4. I would like to experiement with cardioid loading of the mid for get a uniform directionality down to ca 200 Hz.
Aim ia a max SPL of 110 db with very low distortion.
Question is whether the DA32TX00-08 will be able to handle a crossover point at ca 1kHz in this setup, and whether there are better alternavives?
Has anyone seen any measurements on the DA32TX00-08?
KR Baldin
KR Baldin
KR Baldin
Not a bad plan if you are up to the task of designing a waveguide. The waveguide will produce a bump in response that might match the sensitivity of woofer. But 1000 hz seems low even if the xmax is 1mm. If this is active I would try something like 1300 4th order. You might want to consider a small full range or a larger compression driver in a large waveguide if you are set on 1000hz. This is sort of like the Geddes style design. Also an open box won't produce deep bass. You can get better directivity down low with a large baffle.
Sure fully active with DSP.
For the low end I'm considering 6 x Reckhorn D-165.
Yes maybe the Xover freq could be 1.5 kHz ...... but the question is whether this is one of the best drivers to reach this low and with this SPL, if not considering a compression driver?
It seems to be intended for lowish crossover points, but some measurements would be nice. Another one to consider is the transducer labs ceramic dome. They have them at Meniscus. Very nice tweeter that can go low.
Sitting here sketching on a 3d printed Wg-300 clone for my DA32TX00:s, but I cant find the correct horn-curve. Any ideas?
This is MCM waveguide that Zaph used for his TMM speaker. No shame in using that since it measures quite well with Seas tweeter
http://www.zaphaudio.com/WaveguideTMM-profile.pdf
Zaph|Audio
Zaph|Audio
Sitting here sketching on a 3d printed Wg-300 clone for my DA32TX00:s, but I cant find the correct horn-curve. Any ideas?![]()
Did you ever use this? What shape waveguide did you use?
Zaphaudio.com gives ERR_CONNECTION_TIMED_OUT for some months now.
Maybe only online when accessed from US ?
- Whoa, cool new tweeter from Peerless!!
