What thread to use for wire harnesses?
Joined 2017
Hi friends
I just got impressed by both the documentation of the (Aussie) Advisory Circular AC AIRCRAFT WIRING AND BONDING ...
and the bespoke audio passive preamp...
and thought that I should/could do that too. 😀:wrench:
What thread/string can be used to get there? It seems like it's a bit a specialty material, can it be substituted?
Yes of course I could just try'n err, but probably there's somebody more experienced willing to share a bit of knowledge?
david
Your Australian link is for military grade RF cable which would be (usually ) 50 ohms impedance it is manufactured to a high standard so that their are no "reflections " that bring down the bandwidth of the cable and that includes precision machine manufactured .
Even the termination /insulation /mesh insulation are of a special and high standard .
As someone who set up analogue TV transmission cable for outside broadcast while working for BT bunched pairs of twisted cable were used to keep the video signal at a high enough frequency for transmission and using top quality satellite cable for my own large dishes I can assure you cheap homemade stuff doesn't cut it neither does all those cheap brands on the market .
I admire your willingness to try -good on you but this is an area where high quality reigns supreme using cheap /low grade stuff causes all sorts of cable problems .
Thinking -oh its only a connecting cable wont work when you want the quality you want from DIY .
There are plenty of books on cable theory and practice .
If it were just standard low frequency ( audio ) cable then go ahead but you want the engineering quality used by the military/aircraft industry and yes I worked for HA in Kingston -on -Thames for a while and they used very high grade cable with special machine terminations in the P1127 at the time I worked there.
Thank you, Duncan, too
Well, being nearly ignorant on that matter, I'll never be able to cope with the real thing. All I want is some good looking, good sounding gear. So, although I know the aircraft-tech is as unreachable to me as is the _science_ of electronics, I still try to avoid the crap-stuff... just trying to replicate things [emoji56][emoji1308]
the local surplus shop has:
GUDEBROD - WMLTAA52080-A-5 -
Cordage, lacing. Reel, 500 yards 20-125 Mil. Material: Polyamide nylon, MIL-T-43435, type 1 overall. Breaking strength: 15.0 pounds minimum. Color: natural. Note: Alt P/N: A-A-52080-A-5.
$39.99
Years ago I worked for the provincial phone company, in the pre-digital days, the switching offices were, obviously, full of wire bundles snaking everywhere. And they were all neatly tied, with a running stitch (for lack of a better term) with waxed line. The benefit of the wax was that it would hold, long enough, when pulled tight to allow the next loop to be formed.
Any monofilament fishing line works.
Or shoe grade polyester thread, thick enough for stitching shoes, or a close enough in thickness synthetic thread, cotton breaks after some years.
Try a local shop for stitching materials, or get thin twine from a hardware center.
One wire from the four in old keyboards or mice, or a single wire from a bad flat hard disk cable will work too.
Stay away from bare contacts if you use insulated wire.
Single strand insulated wire salvaged from indoor telephone installations, RJ45 cables, they all will do.
just to confirm this thread wasn't for nothing: I experimented a bit with harnessing wires, using dental floss and also a fat (unwaxed) cotton-thread.
whatever thread you use, it seems important to have it waxed because if not the thread tends to slip and the knots to loosen…
This detail put aside, making a harness is really easy, all it takes is that little bit of patience.
The knots, as recommended by the official build-guide, while looking complicated, are the easiest imaginable.
Having those wire-runs grouped is really really helpful in keeping a chassis’s interior free from rats nests. (Other things, like proper arrangement and wire-diameters, matter even more, of course)
Looks better than zip ties 😉
With the waxed aircraft lacing cord, I usually touch the last knot of each run with the soldering iron to melt the wax and make the knot permanent.
CASA AC21-99 is a pretty comprehensive guide for wiring and bonding, and definitely worth the time to read through.
CASA AC21-99
Yes, disliking those zip-cords was the reason I got into it, despite my knack for outlandish handcrafts… the original lacing cord only is available by the (multi-)kilometers, thus my quest for altenatives, but the manual is my reference too 🙂
Now I'm looking for places where I could make some wire-harnesses 😀
