What is wrong with TPA3255?
hi
if you compare to page 29 post #286 to my modification on post #300....its looks better.
i am not an expert, and the laplace or Fourier transformations is too long time ago😀
but its sounds better and on the scope i see the sinus more like a sinus = less harmonic thd....right?
chris
Congratulations with your wedding day! Do not make my mistake and forget it occasionally (result 😡).
You work thoroughly on the power part. I did some analysis on the input part like many other. Perhaps one day the manufacturer may read about our efforts and improve some of our concerns. It need not be costly in manufacturing.
hi
chris
sorry.......... this statement is not fair = correct.
measuremnts on page 29 is 8 ohms load
and now it is the optimized 4ohms output filter with 4 ohms load
i will recheck and show
Hi Abraxalito
AAAh...fine this is exactly my board where i am try something.
According to your answer...you tried the cap on AVDD.
i have 4 boards 2 payed at amazon/nobsound and the other 2 i got because i claimed amazon about the 50V at LM2575S--> so i get 2 for free :clown:😀
now the technical datas are changed to 40V....
other things what you recommend to do?
here is my suggesetion:
1
input caps 6x 10µ/16V (actually a changed the 2 at the audio path with bi polar muse (my last onces😉 - i like the muse 😀
2
bulk caps i tried original (elna or samwha), or nichicon 3300 UFG serie, or nichicon UHE series - in my volume no difference
3
change the LM317 coil wrong 220=22µH to 221= 220µ H
4
change the caps near the LM317 + LM2575S to 220µf - 16YXM220MEFC8X11.5
5
change the output on LM2575 on 2 boards, 1 is still at 12,75V, 1 is completle original
6
avoid short by the heatsink on smd components (is corrected in later versions)
not done:
7
change opamp
8
change
10k smd at opamp to 1% or better tolerance
9 other LC output filter
my DAC is Gustard A20H -cable viablue nf -S6 Silver RCA
thank you...
chris
...pump it up...Abraxalito?
smps test meanwell ..
Hi
after a hard office working week i am back with some measurments. i read in other thread about the smps and so i start a short test for the Meanwell LRS 350-36 and LRS150-24 which i plan to use for my prototype amps.
i want to see the hickup mode and which load is pushing or not.🙂
as i learned from doctor and other here in the forum..with about 12mF or more the hickup mode will not been solved.😀😉
first i my pdf with my measurements
pic 1 LRS350-36 with 2,6ohms load - hickup without caps
pic 2 LRS350-36 with 2,6 ohms load- hickup12mF caps
pic 3 LRS150-24 with 2,6ohms load - hickup without caps
pic 4 LRS150-24 with 2,6ohms load - hickup 12mF caps
pic 5 LRS150-24 with 2,6ohms load - hickup 33mF caps
chris
  • SMPS_Meanwell tests.pdf
Amp light
my first protoype will be a small amp in a litte nice housing.
the "AMP light" 🙂
i will use:
YJ TPA board (after SQ test i will decide which one...here its the original) configuration is for 4 ohm speakers
LRS150-24V because of the limited room in the housing
1 pair RCA connectors
1 power switch with fuse and filter (its the version for a bigger amp but...)
2 pairs of output connectors
1 mute switch for power on/off..actually i haven´t realised doctores mute circuit
cu
chris
Dear Doctormord,
I saw on your website that you were using Codaca inductor, with a similar shape to the Wurth inductors highlighted in TI LC filter design paper.
Maybe difficult to answer, but do you expect those Codaca inductors to result in similar performances to the Wurth ones (not too far away) ?
If not secret, what are the exact ref that you used (they have a quite packed catalog for high current inductors I those values) ?
Best regards,
JMF
output filter
Hi
i want to simulated in the TI Designer for Output filter the difference of my 2 boards for 4 ohms load.
1 board is as recommended by TI 7µH + 1µF
2 board is like the TPA3251EVM 7µ +0,68µF
what should i configure at the input? hybrid, BTL...???
SQ is different between the 2 boards. As expected the board 2 (0,68µf) is slightly smoother in the high.
thx
chris
