Thanks! All I have is this:Look for the driver's impedance curve in the mfr data, not the frequency response curve.
EDIT: I am assuming that RE impedance is the value you normally give a speaker, like 4 Ohm 8 Ohm and that kind?
What is the driver brand and model number? This says you can model it as a 6.5 ohm resistor,
so do that. High impedance = low impedance = 6.5 ohms.
It's BG Neo10 https://www.parts-express.com/pedoc...nder-graebener-neo10-specifications-47008.pdfWhat is the driver brand and model number?
Ok, good luck.
Thank you🙂Ok, good luck.
But I can understand that if I find a mfr graph, I do get the missing values for the low and high impedance?
See post #4.
Thanks a lot and I am sorry for not seeing that reply!See post #4.
I just found this graph, but with no explanation:
That's the magnitude of the impedance (bottom red curve, left scale),
and the phase of the impedance (top green curve, right scale).
Thanks a lot!!That's the magnitude of the impedance (bottom red curve, left scale),
But do I read the impedance right, it looks like 8-10 Ohm but as you correctly stated, it says 6.5 +-5 on the text?
Thanks a lot!!
Each scale division is 0.5 ohm, so it actually is 6.5 ohms.
Many thanks!!Each scale division is 0.5 ohm, so it is 6.5 ohms.
I do know that i may not show it, but your help do mean a lot to me, I am so grateful, thanks for all your help. I also know that I may seem like I don't read half of it, but I try, it's just that English is self thought and electronic is a new wonderful universe where I do know nearly nothing!
For what purpose you're going to use the driver with such a bad freq. response?
It fills in the LF on a baffle, that's the free air response. It's less than 5" wide,
so the free air response drops off below 2kHz.
I heard them on some speakers a long time ago and PS audio has just build some amazing sounding one and as I understand are they farly easy to mount in a cabinet, demands nearly nothing. On top of that did I just chose them to play with on the speaker simulator.It fills in the LF on a baffle. That's the free air response.
What's your native language? English takes kids here years to learn, but we grow up with it.
Can you find electronics books in your native language? Here's a good one in English.
https://www.pearl-hifi.com/06_Lit_A...pers/Horowitz-Hill/The_Art_of_Electronics.pdf
I am so lucky that I do understand English speak fairly good but I takes some more to read it. And my grammar is so bad I wonder how anyone do understand what I am writing.What's your native language? English takes kids here years to learn, but we grow up with it.
There are book in Danish but to be fair, I do not think you can find much newer then 1980 and since YouTube, Fora, Datasheets and so on is in English, do I try to learn it all in English.
Thanks for the link! I do often let the computer read out loud if I want to learn from longer texts!
Good luck, I imagine learning English using technical material is about the hardest way to do it.
- Design & Build
- Software Tools
- What is SPL high and low impedance VituixCAD
