What is Monaural, Dual mono, stereo in fact?
Here is a pic of what I have done! 2 Monacor 60/8 as midrange! Pls help me with some fragvante advice on what I have done for they mmmmmmmmmmmmm sound sooooo very good and allot of bass! Though I am not a fan of bass really!
Pls. don't make me goo deeper into them ! I will in 3 months for sound tuning!
Here is one from the front that I have had saved in my computer, more to come bu I just went on standby with the cam, batteries went empty!
ok! here are the rest of the pics! Danielwritesback might remember the topic uppont these speakers when I asked arround, here on Diyaudio on how to build them, crossover wiring in the correct order, polarity, phase shifting! They sound great!
I think that the almost perfectly flat response of those midrange drivers has eased the task with the active crossover and caused it to work correctly.
Those might even work fine with the DeVore style hybrid series passive crossovers, which, like all crossovers of any type, do benefit from good driver matching, and those monacor are very easy in that regard. . . so there would be better odds of success. And yes, those do resolve the midrange very very well.
What do you have to say pros and cons about the dispersion of sound for the components positioning at a first look? BTW they don't have any cross conflict for the tweeters when the listener lifts itself when listening to them or moving left or right. Others to be mentioned are, the crossovers in them are from HECO ASCADA 770, big floorstanding speakers!
Untill then for not opening another thread, what pots do I need for my Luxman L-410 Treble and Bass knobs? They have broken, here are some pics from the inside!
If they are Alps you can measure the shaft length and use this chart for the new part number. It will be 50kohm dual audio taper.
RK163 Series - Products Line
The part number in the service manual says they are for the bass and treble controls and the same part number.
VR701 V16 K162A-50KEE Bass
VR702 V16 K162A-50KEE Treble
So "RK16" in the Alps catalog appears to be the right series.
Here's some in stock at Mouser
RK16312A0BKH ALPS | Mouser
The knobs will be Luxman parts P/N WK1140...
