what am I not getting about the FF85WK
I'm still around, but got sidetracked by building a work bench, rehabilitating a 70 year old table saw, and making my very small (5'x6') deck a little bigger so I have someplace to park a 125lb table saw. Not exactly a job site saw . . .
The most current incarnation of Unisaw (36-L352-2) weighs in at 660 lbs with Biesemeyer fence and side table - by the time you skirt it with a sturdy full sized run-off table, you're looking at close to half a ton of machinery and 80sq ft of floor space.
every weekend warrior needs one of these 😀
36-L352 Type 2
Ho-ly . . .
Does that come with a job site stand?
nope
but at only 203lbs, this cute little bugger ( 36-725) could possibly be considered "portable"
Now, yur Delta RT31 with scoring blade, that was a nice saw
Nice saws
I see your state of the art and raise you the golden age of industrial manufacturing
I'm glad you asked. they are almost . . . started!
I finished the workbench today so I can start making sawdust. Gonna try and glue up a side or two tonight.
I thought I'd have the boxes done in a day or two. How was I to know that I would build a workbench, inherit a 70yr old table saw and need a larger to deck to keep it on as part of the 'build'.
I'm hoping to have them and a voxel sub finished by the end of the month.
I did order a TPA3116 based 2.1 amp to use for them and the sub. It has a higher cross over than the plate amp I'm using now.
FINALLY got the Lance boxes started. I would have got more done but I decided to fix the loose vice with some bushings since I was going to use that as a clamp. Anyway sides, top bottom and front are glued up. I used 1/2" thick poplar in pre cut sizes. It worked out that I could mix and match to get the sizes I needed for all the parts of the boxes.
Back and baffles tomorrow and maybe a little work on the saw. You ever get to that point you have so much to do that you can't even think about it or you would lose your mind? But i'm happy the speakers snuck to the top of the list finally.
I SWEAR i'm going to build some speakers . . .
The deck is almost done and I have bought a bunch of new tools, including a Dewalt table saw. The 'old' one is finding a home at a friends house who just needs it for the occasional rough cuts.
But the Lance speakers are still close to the top of the list.
Thank all the holy corporeal or non-physical entities, singular and multiple, that may or not exist, in this physical universe or on a spiritual non-dimensional plane; The deck is done.
And there is a dewalt compact router in a box in my living room along with a portable router table for it. Though I'm thinking of 'uprading' to the Bosch bench top router table. Since the one I got is pretty basic.
Trim Router Table - Rockler Woodworking Tools
THAT day is here! I cut honest to god wood for the speakers. Two sides cut to finished size!!! Symbolic.
But EVERYTHING is done now. Workbench, Deck, Table saw setup and tuned, table saw stand built, cross cut sled built. Did I mention that I cut some honest to goodness speaker enclosure wood?
Relief is pouring off of me. I was feeling like Sisyphus . . .
