Weird crossover coil
A-B inductance is zero (0.000) on my LCR meter not Ø, as it tries to measure it but it settles on 0.000. A-B resistance is 0.6 (sometimes 0.5) ohm.
B-B1is null/Ø - cannot be measured because they are 2 diferent wires.
B1-C is 211mH and 0.7(sometimes 0.8) ohm.
B-C (B and B1connected/shorted) is also 211mH but 0.9(sometimes 0.8) ohm.
A-C (without B and B1 connected/shorted) is null (Ø), cannot be measured because they are 2 diferent wires.
A-C (B and B1 connected/shorted) is 0.580mH and 1.2 ohm (sometimes 1.1)
The two windings are the same gauge.
According to these measurements, the inductance between A-B should be around .09mh, or 40% of the total windings. B-C is .211mh, or 60% of the windings. A-C with B and B1 connected is .580mh, or 100% of the windings. I'll assume the driver is connected to B and C, and the input voltage is connected to A and C. The voltage across B-C would be down 4.4db.
@AllenB
Actualy, yes. I get 0.000 mH and about 0.6 ohm.
@mboxler There is no continuity between A, B and C on the PCB.
C is the negative on the PCB and this is where the C from the coil is soldered to.
B(and B1) is connected to the 6.8uF cap and from there to the positive of the tweeter.
There are no components to interfere with the measurements. The coil/autotransformer is out of the pcb. The photos of the pcb and crossover are of the other speaker which is in its original state.
When A-B is shorted, B1-C behaves just like A-B when are not shorted, 0.000mH with "some" resistance.
A-B is the first wire of the coil, B1-C is the second one. A-B has continuity, just like B1-C. A-C has no continuity unless B and B1 are shorted.
Do you have a spare inductor? To verify the measurements, connect it to A and C and connect B to B1. Your parallel measurement between A - C should now be less than .580mh and one can then verify that A - C is truly .580mh. You can also connect the inductor to A - B to see if you still get zero inductance.
It would be a pain but interesting to measure the coils on the other speaker.
Woofer inductance is 0.770
A-X and C-Y (B and B1 shorted), basically a closed loop, is 0.290 mH, 0.2-0.3 ohm.
A-Y is 1.420 mH, 1.4 ohm
Hmmm. A .77mh in parallel with a .58mh should equal .33mh. .29mh is low but close.
Don't understand the 1.42mh measurement. A - Y should be the same as A - C (.29mh)???
Sorry for the wild goose chase. I'm just trying to verify the accuracy of your meter when measuring the autotransformer. Still stumped.
I can think of two more ideas...
1) Remove and measure the mysterious coil in the other speaker
2) Do a voltage test on the one you have already removed. You would need an AC voltage meter and a way to generate a fixed frequency voltage across A - C, then measure the voltage across BB1 - C. That would nail the turns ratio. I'd use a capacitor on the input side and a resistor across BB1 - C on the output side. I wouldn't turn your amp up any higher that 1 volt across A - C.
The zero inductance of A - B is too weird.
I would leave it as is. Coils don't go bad. It would be part of a third order high pass to the tweeter that would be difficult to replace with an inductor and an lpad.
Sorry I was no help. I find auto transformers interesting in a crossover.
