W5-1611sa
W5-1611SA available at AudioExpress
Just got this email from AudioExpress --
Hello-
Thank you for contacting Parts Express. We plan to add the (264-898) Tang Band W5-1611SA 5" Full Range Driver to our product line in the near future. They're currently estimated to arrive within the next few weeks or so. The pricing is as follows:
$53.03 Each (1-3)
$50.50 Each (4+)
The product information will take time to upload to our website. In the meantime, feel free to place an order by phone. We will be help to add your name to our backorder log. You can reach our Sales Reps at 800/338-0531.
We appreciate your business. Please let us know if we can be of further assistance.
Kim Nickell
Customer Service Team
Parts Express International
800/338-0531
sales@parts-express.com
www.parts-express.com
Wow, 30hz from the BiBs? That's very tempting! I'm planning on building the horn Henkjan recommended for the W5s in the next month or so. The BiBs are unfortunately a little big for my space. 🙂 I'll certainly post my thoughts on these speakers once they're finished.
By recommendation from this forum, I think it was Godzilla. I dropped the Fs by a factor of 0.707 and then fudged off a few centimeters so the cab resonance is around 44 Hz. Oddly enough they fall off dramatically below 30 Hz. No idea if theyre supposed to do that. Maybe its a room resonance thing
Theyre big but the footprint is small and being tall plain boxes they dont scream for attention like a more elaborately shaped speaker maybe would
Regards /Bo
I think they were external. I did the math in Godzillas BIB spreadsheet. Pic is posted. My internal baffle is made of 30 mm styrofaom, hence the added depth. I forgot to mention the baffle step EQ it requires. I correceted in the Mac thats my music/film centre. Screen dump included
U can get the spreadsheet here: Bigger Is Better 'BIB' Cabinet Dimensions - ZillaSpeak
Regards /Bo
30hz from the BiB is tempting, but I think I'm pretty much committed to making the horn that Henkjan suggested. I'll be getting to work on it as soon as I can and I will post impressions once I'm done. I have more detailed plans drafted in sketchup if anyone wants them, although I converted the values to inches. 🙂
Henkjan, maybe you can tell me (us) how precise the dimensions of that horn need to be. Since the design you posted is not super detailed, I'm not always certain that I have the dimensions just right, and I'm also running a risk rounding the dimensions to the nearest eighth of an inch. Is this a bad idea? Also, take the placement of the driver, which in your plan is centered at EXACTLY 898mm from the base. Will rounding that to 90cm make much of a difference?
-Chaz
henkjan knows best, but i'd just put clamps on the sides and try lots of stuffing choices to see.
the 'box' sounds will obviously be different when finished compared to when clamped, but you can allow some for that in your head 🙂
i almost built those, too. thanks for sharing. good work--listening fun is close!
I did it like this:Audio-TECH
After listening I stuffed it even more; didnt like the slightly "hollow" sound.
After the speaker broke in, it was better, but the high frequency range was never satifying to me. I applied a helper tweeter, and that did the trick.
A little wile later I switched to the alpair 10, and that was a lot better, but even there I put a helper (ribbon) tweeter at the back.
I have to say that my tube amp sounded very smooth, but after changing the JJ 2a3-40's to TJ300B/2.5 it sounded brighter, so I could remove the tweeters...
greetings, Paul
hi
Thanks guys ,specialy Henkjan for a nice project .
I will play for few days and see what i like best. Alpair 10 looks like a intresting driver.Should i order straight away?🙂...
Audio tech i like your round it corners.Is that paint on your boxes?.
best regards.
