Hi to all GB members and thread followers
Up till now 190 VSSA PCB sets delivered. 😎
8 GB members still on the list to deliver VSSA sets when ALF mosfets will arrive from SEMELAB.
Anyone from this list still not received the VSSA modules? 🙄
Regards Lazy Cat![]()
Hi LC,
I didn't receive my package yet.
Regards.
I got everything ! VSSA assembled and all the stuff, but there is a problem. VSSA is not running. I use 2x26V trafo (as above) connected to PSU (each 26V section to the seperate bridge and then to seperate caps and to VSSA). There should be around 35V on each VSSA, but there is 37V and 34V on each, setting the trimmer does change the offset (and voltage too) but there is nothing on input bias. Like it does not consumpt the power. PSU are grounded together in the star ground (with GND from VSSA too). Any ideas ?
As miksi and me correctly found out R19, R20 installed are standard Yageo SMD2010 resistors and not Vishay as I specified to the producer of PCB. Vishay resistors are current pulse proved type and Yageo are obviously not.
R19, R20 faces current pulse at the power on sequence when C14, C15 are empty of charge. This happens only when SMPS400A180 is used since this power supply starts with full +/-45 V voltage at the moment when TL494 starts to oscillate mosfets on primary. DC voltage on secondary goes from zero to max in a matter of micro seconds so the current pulse to charge C14, C15 is higher than R19, R20 resistors can withstand.
In classic linear power supply rising of the secondary smoothed DC voltage is slow, also the charge current for C14, C15, so there should be no problem with R19, R20.
LC,
what do you suggest if a SMPS is being used ? Should we replace these resistors and could you please provide a part number ?
Thanks !
Renioo firsr check the PSU before you connect it to the VSSA board.You should have
+/-35 V unloaded
+/-35 V unloaded
http://www.diyaudio.com/forums/solid-state/230048-small-amp-renioo-project-8.html#post3548296
It's all in here. Based on VSSA.
The PSU is +- 36V unloaded, but the voltage swings depending on how the PSU is loaded. When there is more load on one board, the voltage swings to another one - and that's really strange.
This means that you load one side more than the other.Not a good thing to do.
Are your DMMs connected correctly? Where are you measuring your consumption? I mean have you put the 22 ohm resistors?
LC,
Thanks !
You should replace R19 and R20 resistors. You can try one of these:
CRCW201010R0FKEF Vishay / Dale | Mouser
CRCW201010R0FKEFHP Vishay / Dale | Mouser
No voltage. These are paralleled 10,10,1,1 Ohm resistors.
You should connect the resistors in series not parallel. You have now less than 0,5 ohm.
Sorry, they're in series. I'm tired today, gonna check it again and maybe I will find something.
Thank you !!
There is 37V on each VSSA approximately now and 53mV voltage drop across resistors. Nothing more I can do, setting the trimmers does not work. All connections on the board are OK.
Measure supply voltage from TP1 to GND. It should be 0,5 V lower than + VDC. If not, check R19, R20 if they are still 10 Ohm.
Hi LC,
Regards.
Me neither!
Will send the tracking number to both. 😉
LC,
Thanks !
Yes change R19, R20 and use VISHAY ones, since these are specified as 10 Ap pulse current peak to withstand. Installed ones are YAGEO 2 Ap max. Guys from production company didn't quite follow my BOM where it was specified VISHAY 2010 10 Ohm/0,75 W type. Sorry for that inconvenience.
- Vendor's Bazaar
- VSSA Lateral MosFet Amplifier
