Voltage Differential Amplification
When I look at this and the associated comment, I'd say it's a recipe for disaster...
That is not to say that the design itself might be pretty fine, and without doubt a discrete design has more degrees of design and execution freedom than an IC design... but then again the "specifications" they give for their design is a joke. With *that* amount of info (read: zero) my conlusion would clearly be "stay away from kitchen-table stuff like that", and the rest of the talk on their site does urge me to think so even more.
- Klaus
I don't know if the Burson opamp is a "disaster" as I have never tested it, however I must agree with KSTR that the information level is quite low...
However if you look at this thread: http://www.diyaudio.com/forums/showthread.php?s=&threadid=127371 you find a link to the John Hardy Company
http://www.johnhardyco.com which has a quite higher information level. And as I recall, Mr. Pass has also written an article on discrete opamps. Pick your choice with care 😉
Another DIY member had problems a while back with these (Burson) modules. Seem to remember there was a seperate ground wire, and there was constant noise no matter how it was connected. I don't know what the final outcome was, but agree with comments so far --- Avoid.
Google translation;
10/25/2007
Burson: technology….
Filed under: General-jipihorn @ 9:09 am
For curiosity, I asked Burson if they had a datasheet on their operational amplifier discreet. Because even if an operational amplifier appears to be a component in almost perfect beaches of work that interests us, they are not interchangeable like that. A current offset misplaced, a gain inappropriate, inadequate and decoupling it no longer works properly. By the way, it would appear that Burson does not work well converter current / voltage output DAC.
So, least of all, when provides electronic components is to provide the relevant characteristics, as is the case of ALL known suppliers…
Answer:
Hi Mr Prevost,
We do not have that but you will be more than welcome to test it out your self.
Jack Thomas
Basically, "we did not like it, but you are welcome to do tests for yourself."
I do not know if I should laugh or not, but it is especially highlighted the seriousness behind. Mind you, given the explanations smokers site, had hardly expect better. Moreover he announced a rate distortion (<0,001%) on the site that has high chances of being put to pretty. If they really have the means to measure, why did he not deliver?
Grotesque, but finally, so in keeping with the spirit subjectivist: why give measures, since there are no correlation with listening anyway… alone!
Jipi.
Burson response :
Hi Mr Prevost,
We don’t have that but you will be more than welcome to test it out your self.
I see, their zero information policy has a good reason... oh well... maybe I should "develop" some table-saw blades and urge them to be my beta testers 😀
Um, okay. . .
"Op-amps aren’t designed for audio. . ."
You’re kidding, right? Have they ever heard of little companies like National Semiconductor, Analog Devices, or Burr-Brown (now TI)?
Sounds like the propagation of subjectivist hyperbole for their financial benefit.
So, your music is recorded through dozens of op-amps, mastered through dozens of op-amps, yet when played back without an op-amp, it is magically “more pure, more open, more dynamic”?!? Um, okay. Oh, that’s right – audiophiles can hear a gnat fart at 50-feet.
list of 3 size of common japan devices
when you have to design and build a new amplifier...
better have this matched
Fet for V gain (input mirror have Voltage gain too)
Transistor for C gain
of course, Complementary and Balanced!
