Hi Patrick,
You could use 6.3VW electros; this position only sees -1.62V across it; not much, and it starts out at 0V so no chance it will be destroyed UNLESS the output device(s) gives up.
Try a 2N5401. Not as much gain, but still very linear and Vceo of 150V.
Hugh
Hugh
Meanman,
If you are having difficulty locating 2200uF / 6V3 as Hugh suggests, then feel free to substitute a 1000uF cap. Your ears won't know the difference (I've tried both) - the only difference is visible on a scope trace with square waves.
Christian
Christian
Meanman,
Christian
I've all the caps exept two 2200µF/16V but i do have the 6V3 version and also doesn't have the KSA992 transistors
The 2sA970 will work as well and it has the same pinout as the KSA992 and about the same gain.
Yes!!!! I've two of those🙂
Yes,i've used this KSA97O instead of KSA992 many times in Slewmaster IPS
Some progress in metal work.
Patrick,
It is 1am here and when I check the forum in six hours I expect your report on this amazing amplifier!
Hugh
Hugh
One blue led or two red led in series for Vbe multip.Problem is I don't have the zener diodes
Two 6v zener in series for G protection.😉
M&M,
Thimios is spot on - you could even use a green led and two small diodes all in series!
Hugh
Hugh
M&M,
Hugh
4148 diodes?
Or I could visit the electronic shop in the nearby town.
Many roads to the Rome🙂M&M,
Hugh
Yes but it will make the quiescent very touchy; the bias adjustment will be very fine but it will be OK
Hugh
Hugh
- Very simple quasi complimentary MOSFET amplifier
