Valve Itch phono
Joined 2009
diyAudio Chief Moderator
Joined 2002
True RMS is for DMMs evaluating correctly the RMS value of non sinusoidal AC. Its DCV range we should use on TP. You could fix your current lower than max allowable before? Is that trimmer OK changing value if tested with ohm meter when power is off?
