Valve Itch phono
They are healthy. If you got any 6N2PEV that can show better voltage drop match between sections, maybe could be even better. But gain matching between channels is all that matters in the end. So wait for that test before changing tubes around.
What values in the divider now? Changed something there?
With what cart? Having input transformer? Check there is no dc on input for cartridge. Then put 300Hz test track on HFNRR test disc and DMM on AC. See that outputs show no more than 1-2dB difference for mV. Match best by swapping some 6N2PEV for best ACmv match between L&R.
OK, SUT can't pass DC to cartridge. Do the channels best output matching test. It will include the cartridge channel difference due to windings, alignment by manufacturer, and anti skating, will not be perfect, but look for no gross differences and try for best input tubes for near AC mV on each output between channels. If you have 0.5mV from a generator give 300Hz sinewave so its only the electronics error.
Pics
