Certainly in the UK there are no plans to scrap FM. I don't think I need to justify a cause for a hobby, my expertise is in digital mobile radio - so its nice to do something more old school. In any case I prefer the FM sound quality. I used to dislike the audio artifacts of MP3 which DAB uses but MP3 encoding has improved a lot over the years. I think the broadcasters still put better sound processing in the FM path, DAB can sound a bit thin. I think there's now DAB+ which uses AAC encoding which is more transparent.
How about a hi resolution stepper motor on the multi gang cap? plenty of inexpensive drivers- arduino to name one. Accuracy to .05 degree.
Would be cool to see gang cap rotate mechanically per programmed freq.
Jim
Jim
Interesting idea - rather like motorised pots. Not sure how you be sure you had the right station maybe some AFC would be needed.
Frequency of station would be defined by # of pulses to stepper.
I would think AFC comp could be introduced as an error voltage, generated by a phase locked loop, then introduced as feedback into the step driver circuit.
It's not a bad deal if you want something to play with. It uses the TA-7343 for the multiplex which is very common in car stereos from the 80s onward. The tuning cap they are using is kind of a waste for FM because that is typically for an AM tuner but I see they have the end sections for FM. A vacuum tube MPX would be much better and would achieve more of the fundamentals for wanting a tube tuner which is depth and full bodied sound. I would keep looking. I like that it's on a board but there are compromises. I couldn't see the schematic all that well but if it's an FET output in the MPX, that would be ok.
An AFC voltage is already present as the DC component of the ratio detector output.Frequency of station would be defined by # of pulses to stepper.
The phase locked loop may not seem like a modern invention . . .
That is until you look at the history of Mr. Armstrong's invention of FM Radio.
Compare the start of FM and the first phase locked loop.
Edit:
I revise my statement, there were early patents on phase locked circuits in the 1930s too.
See it on Wiki.
Edit:
See it on Wiki.
Considering FM is going to be unplugged soon, do you really want to invest your resources in such a challenging project ?
I doubt that, a lot of people are against shutting down those analogue radio stations and although a forced switching to digital transmission would be the ultimate wet dream of radio set makers, it will at least take 5 years or more to get this transition politically done. Just my personal opinion though....
We have warning sirens for when the Russians are coming, here in Sweden, and they are tested at 3pm on the first monday of every month.
A couple of years ago, following an error during maintanance, the alarm went off in the Stockholm area at 10pm on Saturday night, causing a lot of consternation.
Now, the procedure is to to immediately switch on the radio to receive further instructions, but not everyone has a radio anymore, and people use TV services from everywhere, so it proved to highlight how dependent we are on a source like radio, as a common and basc means of disseminating information.
+1 to baudouin0's statement on FM sound quality! I've got a Yamaha NP-S2000 network player two months ago that, alongside many other features, allows me to listen to an apparently infinite number of internet radio stations. After I bought it, I initially intended to discard my 1980ies Dual CT 1450 synthesizer AM/FM tuner. But after having carefully compared the sound quality of the same station between both units, I decided that the analog Dual has to stay 🙂.
Best regards!
Best regards!
Yep I have the actual kit. It something to try out rather than an end project and learn from. The IF part looks sound and RF is probably wanting in the selectivity and sensitivity department. I will put some ideas on this post as I get get them. I think I saw valve MPX's on another thread.
The trouble with DAB is bitrate costs money. Plus MP3 does not get much better as your increase bitrate. So the audio quality is usually not the best. FM you get your own 250KHz of channel rather than sharing with others. AAC is much better than MP3 and is pretty transparent at higher bitrates - roll on DAB+.
Nice, My comment with so many high Q tuned circuits it may be difficult to get the 38KHz phase stable with temperature and drift.
sorry I didn't intended to tell anyone what he has to do. In Switzerland FM is gradually being phased out for DAB+, with an end in 2024, as of current plans. I do not endorse this change, it's simply what I got from diverse official sources. And yes as in Sweden we still do have the "listen the radio" habit when the yearly sirens test is ongoing on the 1st Wednesday of February... only nobody has a FM radio anymore.
Not at all don't mind. The trouble is even FM distribution for many stations has gone internet with a MP3/AAC decoder plugged into the transmitter. There's nothing that wrong with AAC except DAB+ you pay for your bandwidth so guess what will happen.
@Eli D.: That L6/C23 35 kHz bandstop filter should better read 38 kHz, shouldn't it? Anyway, it's resonant frequency calculates to about 30 kHz...🙄
Best regards!
Best regards!
I don't think the exact frequency of that filter is important. That filter keeps out of audio band "trash" from appearing at the decoder's O/Ps, when it's operating in mono mode.
I don't understand how L6/C23 works as a low pass filter.
It looks like a series trap - blocks the resonant frequency, passes everything else. And the resonant frequency looks way off. Stray capacitance won't be enough to make much difference at these low frequencies.
I would ( did, actually ) use an MC/LM1310 and be done with it.
Yes, this resonant circuit is a notch filter intended to block the 38 kHz LO frequency. And it's component values are way off...🙄
Best regards!
Best regards!
- Tubes / Valves
- Valve FM receiver
