Vacuum Tube SPICE Models
Thanks mate very much appreciated. Having a play with it now. I want to try and use it to compare UL curves for the 6BQ5 which could be a amp project on another forum. When I learn more about push pull amps I might try to build or restore a small guitar amp for my kid.
Yes, you can detect U1 for SE operation if you modify the operating point as follows:
.param Va=0
.dc v3 0 450 1 v1 36 -36 -9
Keep the rest unchanged, this gives horizontal scale 0-450V for the SE curve plot.
Koonw
I may be going awry somewhere. I was hoping to see more classical UL type curves
  • pp load line-UL-2.asc
Rather than asking to modify PP model, use this model which is intended for SE amp. You can plot any other tube by changing the tube name say 6bq5 (EL84), you should have 6bq5 model on display directive or as statement ".lib 6bq5.inc" where model files "6bq5.inc" is located in lib directory of LTSpice.
You change .dc sweep range to suit your plot. ".dc" function can be modified directly or click on "Simulate" -> Edit Simulation Cmd" -> DC SWEEP, then change the "1st Source" which is anode range and "2nd Source" which is the grid 1 range to suit. You can also change ".param UL=0.43" if you want to plot other curve, so "param UL=0.33" plot curve for 33% UL tap.
Here 6V6GT GE model, original curve has triode, grid#1 and grid#2 current curve:
Code:
**** 6V6GT ******************************************
* Created on 08/20/2021 15:48 using paint_kip.jar
* [url=http://www.dmitrynizh.com/tubeparams_image.htm]Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively[/url]
* Plate Curves image file: 6v6gt.png
* Data source link: <plate curves URL>
.SUBCKT 6V6GT P G2 G K ; LTSpice tetrode.asy pinout
* .SUBCKT 6V6GT P G K G2 ; Koren Pentode Pspice pinout
+ PARAMS: MU=10.7 KG1=1676.38 KP=46.44 KVB=1412.81 VCT=-0.0399 EX=1.306 KG2=2635.52 KNEE=9.75 KVC=1.67
+ KLAM=1.5E-9 KLAMG=1.35E-4  KD=0.02767 KC=0.2692 KR1=1.112E-5 KR2=0.06456 KVBG=0.01817 KB1=1.299 KB2=3.194 KB3=1.125E-5 KB4=0.98 KVBGI=3.975E-6 KNK=0.1559 KNG=0.00951 KNPL=1.145E-6 KNSL=3.87E-4 KNPR=0.4664 KNSR=84.99
+ CCG=0.7P CGP=9P CCP=7.5P VGOFF=-3.6 IGA=8.688E-5 IGB=0.007008 IGC=15 IGEX=3.236
* Vp_MAX=500 Ip_MAX=140 Vg_step=5 Vg_start=0 Vg_count=14
* X_MIN=37 Y_MIN=25 X_SIZE=731 Y_SIZE=516 FSZ_X=1288 FSZ_Y=723 XYGrid=false
* Rp=1400 Vg_ac=20 P_max=12 Vg_qui=-32.5 Vp_qui=300
* showLoadLine=n showIp=y isDHP=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=y isInputSnapped=y addLocalNFB=n
* XYProjections=n harmonicPlot=y dissipPlot=n
* UL=0.43 EG2=250 gridLevel2=y addKink=y isTanhKnee=n advSigmoid=y
RE1  7 0  1G    ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1   7 0  VALUE=  ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(G2,K)/KP*LOG(1+EXP((1/MU+(VCT+V(G,K))/SQRT(KVB+V(G2,K)*V(G2,K)))*KP))}
RE2  6 0  1G    ; DUMMY SO NODE 6 HAS 2 CONNECTIONS
E2  6 0  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))} ; Kg1 times KIT current
E4   8 0  VALUE={V(P,K)/KNEE/(KVBGI+V(6)*KVBG)}
E5  81 0  VALUE={PWR(V(8),KB1)}
E6  82 0  VALUE={PWR(V(8),KB2)}
E7  83 0  VALUE={PWR(V(8),KB3)}
E8   9 0  VALUE={PWR(1-EXP(-V(81)*(KC+KR1*V(82))/(KD+KR2*V(83))),KB4)*1.5708}
RE4  8 0  1
RE5 81 0  1
RE6 82 0  1
RE7 83 0  1
RE8  9 0  1
RE21 21 0 1
E21  21 0 VALUE={V(6)/KG1*V(9)} ; Ip with knee but no slope and no kink
RE22 22 0 1 ; E22: kink curr deviation for plate
E22  22 0 VALUE={V(21)*LIMIT(KNK-V(G,K)*KNG,0,0.3)*(-ATAN((V(P,K)-KNPL)/KNSL)+ATAN((V(P,K)-KNPR)/KNSR))}
G1   P K  VALUE={V(21)*(1+KLAMG*V(P,K))+KLAM*V(P,K) + V(22)}
G2   G2 K  VALUE={V(6)/KG2*(KVC-V(9))/(1+KLAMG*V(P,K)) - V(22)}
RCP  P K  1G     ; FOR CONVERGENCE
C1   K G  {CCG}  ; CATHODE-GRID 1
C2   G P  {CGP}  ; GRID 1-PLATE
C3   K P  {CCP}  ; CATHODE-PLATE
RE23 G 0 1G
GG G K VALUE={(IGA+IGB/(IGC+V(P,K)))*(MU/KG1)*
+(PWR(V(G,K)-VGOFF,IGEX)+PWRS(V(G,K)-VGOFF,IGEX))}
.ENDS
8185 model, try it:
Code:
**** 8185 ** Advanced Grid Current **********************************
* Created on 08/22/2021 11:30 using paint_kit.jar 3.1
* [URL="http://www.dmitrynizh.com/tubeparams_image.htm"]www.dmitrynizh.com/tubeparams_image.htm[/URL]
* Plate Curves image file: 8185.png
* Data source link:
.SUBCKT 8185 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=6P  CGP=5P CCP=0.3P
+ MU=47.04 KG1=84.83 KP=376 KVB=282 VCT=0.1888 EX=1.21
+ VGOFF=-0.6 IGA=6.25E-6 IGB=0.189 IGC=11.76 IGEX=1.38
* Vp_MAX=450 Ip_MAX=60 Vg_step=1 Vg_start=0 Vg_count=9
* Rp=4000 Vg_ac=55 P_max=4.25 Vg_qui=-48 Vp_qui=300
* X_MIN=37 Y_MIN=16 X_SIZE=841 Y_SIZE=565 FSZ_X=1296 FSZ_Y=736 XYGrid=true
* showLoadLine=n showIp=y isDHT=n isPP=n isAsymPP=n showDissipLimit=y
* showIg1=y gridLevel2=y isInputSnapped=n
* XYProjections=n harmonicPlot=n dissipPlot=n
E1 7 0 VALUE={V(1,3)/KP*LOG(1+EXP(KP*(1/MU+(VCT+V(2,3))/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G  ; TO AVOID FLOATING NODES
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G   ; TO AVOID FLOATING NODES
C1 2 3 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
RE2 2 0 1G
EGC 8 0 VALUE={V(2,3)-VGOFF} ; POSITIVE GRID THRESHOLD
GG 2 3 VALUE={(IGA+IGB/(IGC+V(1,3)))*(MU/KG1)*(PWR(V(8),IGEX)+PWRS(V(8),IGEX))}
.ENDS
ECC99 JJ model:
Code:
**** ECC99 ** Advanced Grid Current **********************************
* Created on 08/22/2021 00:55 using paint_kit.jar 3.1
* Plate Curves image file: ecc99.png
* Data source link:
.SUBCKT ECC99 1 2 3 ; Plate Grid Cathode
+ PARAMS: CCG=5.8P  CGP=5.1P CCP=0.91P
+ MU=23.6 KG1=437.25 KP=170 KVB=2.247 VCT=0 EX=1.484
+ VGOFF=-0.6 IGA=5.6E-4 IGB=0.141 IGC=11.28 IGEX=2
* Vp_MAX=400 Ip_MAX=50 Vg_step=2 Vg_start=0 Vg_count=11
* Rp=4000 Vg_ac=55 P_max=5 Vg_qui=-48 Vp_qui=300
* X_MIN=76 Y_MIN=22 X_SIZE=737 Y_SIZE=610 FSZ_X=1296 FSZ_Y=736 XYGrid=false
RE2 2 0 1G
.ENDS
Hello,
Please, I have a question for the 2P29L model bellow:
** 2P29L TRIODE ************************************************************
* Created on Fri Jun 15 19:29:17 BST 2012 using tube.model.finder.PaintKIT
* model URL:Bartola® Valves – All about electronic valves and hi-fi
.SUBCKT 2P29L-T_AM 1 2 3 ; A G K
+ PARAMS: CCG=6P CGP=8P CCP=4P RGI=2000
+ MU=9.1 EX=1.4 KG1=2445 KP=140 KVB=21 VCT=-0.46 ; Vp_MAX=200.0 Ip_MAX=0.08 Vg_step=2.0
RE1 7 0 1G
D3 5 3 DX ; FOR GRID CURRENT
R1 2 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
When I run it, I have the following error:
"Port(pin) count mismatch between the definition of subcircuit "2P29" and instance "xU1" ...".
For xU1 I have used the standard Triode model.
Do you know what is wrong ?
Thank you in advance.
Pierre
If you have problem running any of my model incomplete or slow, try to configure the Control Panel of LTSpice as attached it works like magic: fast and complete. If this works for any other model other than Paint, let's know thanks.
Matrix Compiler > pseudo code or off
Now it's ok.
Two errors from me
1/ Into the definition of the triode:
SpiceModel = 2P29L_T_AM
Value=2P29L_T_AM
and
Directive : .lib "2P29L_T.txt"
2/ Into the file description I had
But KG1 was defined elsewhere into the file as KG and not KG1, so modified the description file.
Hi Koonw, thank you for your support.
Rgds,
Pierre
