** in place of ^ is a LTSpice syntax quirk.
Thanks. much appreciated. I'm slowly becoming familiar with the spice macro language.
How does PSpice compare to Tina? (free versions of each) Does anyone know?
A new real time SPICE simulation program that might be of interest to some, especially for those of us that design guitar amps.
So, I haven't looked around yet, so pardon my laziness, but anyone have a spice model for the KT120 from TungSol?
http://www.tungsol.com/tungsol/specs/kt120-tung-sol-specs-curves.pdf
Seems like a really powerful output tube.
and then there's the KT150:
http://www.tungsol.com/tungsol/html/kt150-tung-sol.html
I have not seen one, but they are basically KT88 with higher dissipation limits and plate/screen current, so you can use the KT88 model with some scaling factor.
I create tube models of my own tubes by using a Tube tracer developed by a Dutch engineer (Ronald Dekker) and an ExtractProgram from Derk Reefman using the Tube tracer data. This results in an exact model for LTSpice and the project I want to realise. Many audiophiles have built their Tube Tracer, called uTracer, over the whole world. I give here the link to the site where you can find all info about this super device. (The uTracer, a miniature Tube Tester / Curve Tracer.).
I haven't tested this, but here ya go...So, I haven't looked around yet, so pardon my laziness, but anyone have a spice model for the KT120 from TungSol?
Code:
.SUBCKT KT120 1 2 3 4 ; A G2 G1 C
* New Sensor website
* library format: LTSpice 19-Sep-2008
X1 1 2 3 4 PENTODE1 MU=9.14 EX=1.350 KG1=612.3 KG2=4500 KP=31.40 KVB=20.0 VCT=0.00 RGI=1000 CCG=29.0p CPG1=1.8p CCP=10.0p ;
.ENDS KT120
.SUBCKT PENTODE1 1 2 3 4 ; A G2 G1 C
RE1 7 0 1MEG ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1 7 0 VALUE={V(2,4)/KP*LOG(1+EXP((1/MU+V(3,4)/V(2,4))*KP))} ; E1 BREAKS UP LONG EQUATION FOR G1.
G1 1 4 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,4)/KVB)}
G2 2 4 VALUE={(EXP(EX*(LOG((V(2,4)/MU)+V(3,4)))))/KG2}
* G2 2 4 VALUE={PWR(V(2,4)/MU+V(3,4),EX)/KG2}
RCP 1 4 1G ; FOR CONVERGENCE A - C
C1 3 4 {CCG} ; CATHODE-GRID 1 C - G1
C2 1 3 {CPG1} ; GRID 1-PLATE G1 - A
C3 1 4 {CCP} ; CATHODE-PLATE A - C
R1 3 5 {RGI} ; FOR GRID CURRENT G1 - 5
D3 5 4 DX ; FOR GRID CURRENT 5 - C
.ENDS PENTODE1
Here's a triode connected KT120 I found on Tube DIY Asylum
Code:
* KT120So2k8 LTSpice model
* Modified Koren model (8 parameters): mean fit error 1.664mA
* Traced by erik 25/12/2013 using Curve Captor v0.9.1
* from sofia tracer
* kt120so2 LTSpice model
.subckt kt120so2k8 P G K
Bp P K I=(0.09616726061m)*uramp(V(P,K)*ln(1.0+(-0.1983471212)+exp((0.5067247971)+(0.5067247971)*((28.86336585)+(2.153515075m)*V(G,K))*V(G,K)/sqrt((-0.1596450898)**2+(V(P,K)-(-9.567928489))**2)))/(0.5067247971))**(1.391876027)
Cgk G K 10.2p ; 0.2p added
Cpk P K 9.3p ; 0.5p added
Cgp G P 29.5p ; 0.5p added
Rpk P K 1G ; to avoid floating nodes
d3 G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends
That looks like a fun project! thanks.
If this model doesn't work for you in TINA, let me know. 🙂Code:.SUBCKT KT120 1 2 3 4 ; A G2 G1 C * New Sensor website * library format: LTSpice 19-Sep-2008 X1 1 2 3 4 PENTODE1 MU=9.14 EX=1.350 KG1=612.3 KG2=4500 KP=31.40 KVB=20.0 VCT=0.00 RGI=1000 CCG=29.0p CPG1=1.8p CCP=10.0p ; .ENDS KT120 .SUBCKT PENTODE1 1 2 3 4 ; A G2 G1 C RE1 7 0 1MEG ; DUMMY SO NODE 7 HAS 2 CONNECTIONS E1 7 0 VALUE={V(2,4)/KP*LOG(1+EXP((1/MU+V(3,4)/V(2,4))*KP))} ; E1 BREAKS UP LONG EQUATION FOR G1. G1 1 4 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,4)/KVB)} G2 2 4 VALUE={(EXP(EX*(LOG((V(2,4)/MU)+V(3,4)))))/KG2} * G2 2 4 VALUE={PWR(V(2,4)/MU+V(3,4),EX)/KG2} RCP 1 4 1G ; FOR CONVERGENCE A - C C1 3 4 {CCG} ; CATHODE-GRID 1 C - G1 C2 1 3 {CPG1} ; GRID 1-PLATE G1 - A C3 1 4 {CCP} ; CATHODE-PLATE A - C R1 3 5 {RGI} ; FOR GRID CURRENT G1 - 5 D3 5 4 DX ; FOR GRID CURRENT 5 - C .ENDS PENTODE1
Thanks, but no, it doesn't compile or what ever macros do to become something useful in Tina. I think Tina only recognizes "P" for plate, for one thing. I don't have any information about Tina's macro language so I'm completely clueless except for banging my head against the wall.
I made "P" and "K" consistent throughout and it still doesn't work:
.SUBCKT KT120 1 2 3 4 ; P G2 G1 K
.ENDS KT120
.SUBCKT PENTODE1 1 2 3 4 ; P G2 G1 K
C1 3 4 {CKG} ; CATHODE-GRID 1 C - G1
C3 1 4 {CKP} ; CATHODE-PLATE A - C
.ENDS PENTODE1
It shows up in Tina as some kind of weird thing that I don't recognize.
.ENDS KT120
.ENDS PENTODE1
Well known here, several of us have one. I find mine extremely useful, can't imagine a more useful tool for characterizing tubes and also creating models for spice.
I have not yet tried Derk's algorithms, but plan to relatively soon when I return from phono pre-amp design hell.. 😀
Sorry about that. This one works in TINA.
Code:
* KT120 Pentode
* Connections:
* Plate
* | Screen
* | | Grid
* | | | Cathode
+ PARAMS: MU=9.14 EX=1.350 KG1=612.3 KG2=4500 KP=31.40 KVB=20.0
+ VCT=0.00 RGI=1000 CCG=29.0p CPG1=1.8p CCP=10.0p
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS KT120
Someone is looking for a pentode model for type 32 over at yahoo groups, could one of the uTracer users be kind enough to trace one and generate a model for him? He is particular interested in the low plate voltage region, so none of the tools like Ayumi, PaintModelTool works...
Which LTspice model for the 6DJ8/ECC88/6922 ???
I have tried 4 different and they give me very different results...
Thanks! much appreciated. I had to fiddle with the drawing selection, but it works great. I think Tina prefers "P G2 G1 C" to "1 2 3 4".
Is there a model for the D3A tetrode/pentode? I've got a triode version.
Did you compare them with the datasheet? Whichever is the closest, would be the one to use.
The one which is closest gives me 177v on B+. In the real life its 144v.
Quite a different.
Do you have one that you are using ????
/Michael
As usual, I use the Ayumi model, here is the comparison with the Philips datasheet:
Here is the model:
Here is the model:
Code:
* Generic triode model: ECC88
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Mar 8 22:42:43 2008
* Plate
* | Grid
* | | Cathode
.SUBCKT ECC88 A G K
BGG GG 0 V=V(G,K)+0.34001426
BM1 M1 0 V=(0.009343174*(URAMP(V(A,K))+1e-10))**-0.49661195
BM2 M2 0 V=(0.75127268*(URAMP(V(GG)+URAMP(V(A,K))/26.621288)+1e-10))**1.9966119
BP P 0 V=0.007130155*(URAMP(V(GG)+URAMP(V(A,K))/35.434921)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0041180199*V(M1)*V(M2)
BIG IG 0 V=0.0035650775*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0038690245*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 1.4p
CGK G K 3.3p
CAK A K 1.8p
.ENDS
Here is the model:
Code:* * Generic triode model: ECC33 * Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved. * Version 3.10, Generated on Sat Mar 8 22:42:38 2008 * Plate * | Grid * | | Cathode * | | | .SUBCKT ECC33 A G K BGG GG 0 V=V(G,K)+0.39854224 BM1 M1 0 V=(0.00456874*(URAMP(V(A,K))+1e-10))**-0.2251333 BM2 M2 0 V=(0.86949802*(URAMP(V(GG)+URAMP(V(A,K))/28.564106)+1e-10))**1.7251333 BP P 0 V=0.001087821*(URAMP(V(GG)+URAMP(V(A,K))/32.85126)+1e-10)**1.5 BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00070978374*V(M1)*V(M2) BIG IG 0 V=0.00054391049*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4) BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.00059395688*URAMP(V(A,K))**1.5)))+1e-10*V(A,K) BIGK G K I=V(IG) * CAPS CGA G A 2.5p CGK G K 3.5p CAK A K 1.5p .ENDS
Your model is for the ECC33. I didn't think this was equivalent to the ECC88 (6DJ8/6922).
- Tubes / Valves
- Vacuum Tube SPICE Models
