USB to S/PDIF converters
I presume that a good USB to SPDIF converter has to also have its own power supply.
There is not much point since S/PDIF is usually isolated by a transformer or TOSLINK transmitters. The jitter would be dominated by receiver’s pll.
Reactions: miro1360
JL Sounds I2SoverUSB is probably the preferred solution for now. Best if powered from two isolated clean linear 5v power supplies. Better yet if also supplied with external ultra-low close-in phase-noise clocking, and then by reclocking the SPDIF and or I2S outputs. For I2S signals, a fair amount of discussion exists in other threads: https://www.diyaudio.com/community/threads/general-purpose-dac-clock-board.413001/ and: https://www.diyaudio.com/community/...2soverusb-pcm2dsd-rtz-dac.423401/post-7917601
Shouldn't be too hard to modify either a board or a set of boards for SPDIF instead.
Galvanic isolation for one thing. Its a separate issue from reclocking.
Regarding Holo USB board, if you are referring to this thing: https://www.magnahifi.com/shop/ha-u...BmILSYnUcpI_yyh1U#attribute_values=43,181,754 or to the device at: https://www.audiosciencereview.com/...ments-of-holoaudio-xeme2ve-usb-to-spdif.6386/
...I would consider it virtually certainly inferior to what we know how to do here, if we we both reclock and isolate, especially if using SC cut crystal oscillators. You might want to seriously read the threads I linked to if you want a better ideal of what is possible.
NOTE: However, I will say it interesting to see ASR doing noise skirt measurements. Its been a long time coming.
There is Cestrian's board with Iancanada SC Pure clocks... The reviews if its used with a good dac are exceptional. Best dac most people have ever heard.
You might want to patch the 3.3v LVCMOS SPDIF signal from I2SoverUSB through one of the reclocking flip flops. Could be you would need to tweak the timing a little, so a 100MHz or better, 2-channel or better, scope is strongly recommended (actually its strongly recommended for any kind of dac work).
What do you mean by a digital unit? A digital oscilloscope?
BTW, 100mhz might refer to 0.1Hz, a value we sometimes use in reference to dac clock measurements. Probably better to use the correct nomenclature for million instead of milli, e.g. 100MHz.
Reactions: altor
Thanks much. I know there are certain applications still for an analog unit, but they are things I'm no longer planning on doing (and trying to lighten my load before a move). I do like the build quality of these Tek units, but lots of advantages to a modern digital oscilloscope these days - and lots to potentially go wrong with an ancient piece of gear 🙂
