USB to S/PDIF converters
SMSL PO100 pro. I2S, SPDIF and coax output.
Could be a board that converts USB to either I2S or SPDIF. Should be a few of those, including JLSounds and no doubt chi-fi ones.
Please have a look at York, it can output I2S and S/PDIF at the same time, and there are many other modes to interface PCM DACs directly too:
Thanks kazuviking. That is in the right direction. While looking at the SMSL device I came across another one from Douk Audio. I found their products to be excellent in the past. The Douk box has the large form factor USB A connector that I find is much more robust than the USB C, which I tend to break with a single accidental bump of the cord on small devices. I would also like to avoid supporting the MQA con.
Douk Audio U2 PRO XMOS XU208 Digital Interface, USB to TOSLINK Coaxial/Optical/HDMI IIS Audio Adapter, for DAC/Preamp/Amplifier, Support PCM & DSD256
https://www.amazon.com/Digital-Interface-Coaxial-Optical-Audio/dp/B08HN3VSF8
I clicked buy before I saw your post. I will give it a try. Returns are very easy with Amazon. These converters are such simple devices, a CPU chip, a few caps and connectors, that there's very little to go wrong. Worst case it dies in a year and I have a nice case with all the required connectors that I could put a DIY solution into.
Reactions: Zeta4
JL Sounds needs two mutually isolated 5v power supplies to sound its best. It could then be bettered further using external clocking and reclocking the SPDIF output. That setup, with good clocks, could probably beat any SPDIF source out there.
However, SPDIF by its nature is flawed. The SPDIF signal carries both digital and analog information. The analog information is clock timing, and SPDIF is known for adding clock jitter. Clock jitter is every bit as bad as amplitude noise on the Vref (AVCC) terminal of a dac chip.
