there are many boards out there:
ABC PCB
Amanero
QNKTC
WaveIO
HiFi Diy
I2SoverUSB
exaDevices $430!
and some on eBay
any idea for the best one? or best SQ?
best regard anyhow
ABC PCB
Amanero
QNKTC
WaveIO
HiFi Diy
I2SoverUSB
exaDevices $430!
and some on eBay
best regard anyhow
I have owned several of these. Below is what I think of each. YMMV
EXAU2I - Still in my system, hooked up through a BIII / Legato III. There are still times I am shocked how good this sounds. Plays up to 384 kHz and plays native DSD as 352 kHz 64 bit. (or something like that). DSD sounds pretty good this way. I wish George would update it to full DSD. I am sure it can do this, given that it uses the same hardware as some of his other commercial products that do DSD natively.
DIYINHK - I have had several of these, not the latest isolated output version however. Surprisingly good. Stable and takes everything up to 384 kHz. I am not sure I would buy an EXA again if the one I have stopped working. Great for the money.
Amanero - Very similar to the DIYINHK. Sounds great and works without problems.
I2SoverUSB - By far my least favorite. I find it to be clinically dark in nature. I just don't like listening to music with it. Tried it with the chip powered by the USB buss and from an external supply, very little difference.
I can not comment on the others. Overall it is surprising how good these have become considering the low purchase price.
John
John
Had two EXAs which were great. Sold both in a flash after buying I2SoverUSB. After all the EXA had no reclocking after the isolators...
@Nosian,
Are PC drivers included with these dev boards? Or is it necessary to get a license from Thesycon for this?
@kuribo
There is of course the USBStreamer from miniDSP.
With a suitable interface it can be isolated and get very low jitter.
@kuribo
The Evaluation Driver is available as a free download from xmos.com for evaluation and prototyping purposes only and will work with all XMOS Reference Designs and Development Kits. 🙂
Note that the Evaluation Driver provides all the features of the Thesycon Driver but will generate a short beep tone every 5 minutes after 60 minutes of operation. 😱
Hp
Thanks but it doesn't ship to the US....
Best sounding USB to I2S
Dear johnmarkp,
Thank you for the guidance. Would you still recommend the Amanero or DIYINHK for USB to I2S ?
All the best.
John
Dear johnmarkp,
All the best.
I have the Amanero, WaveIO, and DIYINHK. They all sound good. Best sound so far is the Amanero with the ACKO reclocker.
Which USB to I2S ?
Thank you Raj1.
Have you heard the JLSounds ?
It seems the options are the
JLSounds with Oscillator board
Amanero with ACKO
Or either with Ian's FIFO
Been very interested in Statman's thread on No Dac, No USB thinking to start with either the JLSounds or Amanero USB input than upgrading to I2S. Some people prefer the Amanero to the JLSounds. Planning AD1865 or TDA1541 Dac.
Suggestions ? Thank you !
Thank you Raj1.
Amanero with ACKO
More better than Amanero!
Top Quality Hi End USB I2S Converter PCM 44 1 384kHz DSD512 DOP Asio for DAC | eBay
Can't take that into account I'm afraid. Dark in nature ? Not at all. Heard it in 3 systems and it's not what we are hearing. We find it very natural and I have a hint that it might be little too analytical at the high freq spectrum, I'll find out for sure when I get mine.
We tested both versions (old one with XpressO clocks)
Changes in power supply, either for clocks or usb part, makes a difference you can easily hear too.
Again, it's not just me and not only one system and one time listening test
I got this one a few years ago, it sounded good.
DDDAC1543 MK2, circuit description and Construction
I then modified it with a tube output:
more info at (2/3rds down this page):
Modifying CD player DAC circuits
This looks very expensive to me. Its not isolated is it? I can't see any evidence.
I've used JLSounds and DIYinHK boards, both isolated and they were much cheaper. I can't say that they sounded different to each other, nor should they.
This looks like a real rip-off. No isolation, no reclocking, no native dsd. Being not XMOS based could be an advantage but the lack of assured driver support may one day park it where the EXA is today.
- Digital Source
- USB to i2s please, which sounds best?
