USB to I2S: M2Tech vs XMOS vs Open-source Qnktc
I sell the M2Tech USB to I2S module by AckoDAC (https://sites.google.com/site/ackodac/home) at 80 euro + shipping
Hi, may be I'm on the wrong thread, but now I see you tested QNKTC DAC: have you had any issues with this DAC and Mac OSX?
I have this DAC. With windows and Asio plus Foobar 2000 it works perfect. But I recently bought an Imac with OSX (snow leopard) and when using this DAC with itune or VLC media player or Cog player (there is no foobar for mac), after a while I have distortion in sound. It's very strange because it works fine for a few songs and then it's a kind of electric distortion. I'm going to install a windows partition and try also. But it surprise me because I saw that OSX doesn't need any Asio drivers, it's natively. I also changed settings with Midi Application, but nothing at all goes on.
Well if you heard any thing similar with these Dac's and OSX I would appreciate much your help.
Thanks. Bye.
JOHN
Thanks. Bye.
JOHN
You'd probably be better served by posting your question on this thread:
http://www.diyaudio.com/forums/digital-source/185761-open-source-usb-interface-audio-widget.html
Passive I/V for 1955
Andrea,
Can we run AD1955 passive like this to be compliant with the datasheet? With 2K load, there should be about 400mv RMS at output.
I have tested many configurations with AD1955 and output transformers but always I get bad results (http://www.ti.com/lit/an/slaa399/slaa399.pdf).
To get a flat frequency response and low distortion the best method is a pure resistor followed by a high impedance stage like a vacuum tube.
The 200 ohm value has been found after many test from 47 to 2Kohm.
I should receive soon the first pcb of my hybrid output stage.
USB DAC 2 - Hi-Resolution System
Qh (http://www.quanghao.com/)will sell these pcb and the complete kit at very low cost.
Thanks Andrea, looking forward to your SEN I/V test.
Here the controller to get data from XMOS module and configure any DAC like AD1955, DSD1794, ES9018 ....
IR remote command for the volume and mute.
M2Tech and Open-source Qnktc sold.
Hello
I forgot to mention the USB -> I2S device I am currently using so the units I am using that are worth mentioning are: Light Harmonic Titan USB -> I2S, M2Tech USB -> I2S, QNKTC / Audio Widget USB -> I2S and exaU2I USB -> I2S...
Hello i started to test and translate i2s to TDM but i have no experience but still trying harder.. i red many of papers that how i2s works but no clear small examples for programming on c or c++. first i want to have little example that how to pragramming i2s and want to test my own source of kit based on XMOS with appropriate software.
My kit is USB AUDIO Multi Channel kit. i lost much time i want it step by step but its is too late to do that because i have few weeks to finish my project.
May it stupid questions for you but i couldnt find such a example and software yet. Any one advice or lead me would be appreciated.. thanks
