Ural Warhead 1.1800 repair and overall health check
If the multimeter probe causes the same problems, connect the scope across the gate and source to see what changes when you touch the drain.
The first, low amplitude waveform may have been noise. It wasn't a good drive. Touching the drain may simply have triggered the rail-rail oscillation which caused the increase in current.
You can also try simply driving a signal into the amp to see if that makes the same changes as touching the drain.
yeah, driving a signal into it from my phone does trigger it.
Oh, CCS pot was still slightly increased, brought it back to stock values and now the bad drive is gone. Current draw about 1.47A
testing the low side (both sides still on the single previous 31n20d fet)
low side gate to source:
the high side:
There are some differences from the high side, could that be why the high side is heating up and not the low side?
I could try putting in a few more of the 31N20Ds to see how it changes if needed
