I don't see a problem with adding mass; I know it gives better control, clarity and a bigger - and tighter - bass. It's just that I don't have a clue as to the sonic results I'd get from using compliant mounts between the transport and the chassis.
firmware request
Hi Jon.
I would like to receive your firmware updates concerning the transport noise.
Had mine reclocked with LCaudio's.
Excellent result but transport noise persists.
Hi Jon.
Staaled,
Ok, but please enable your email !
Jon
Jon
Firmware update
Hi Jon,
I also want to try updating firmware of 963SA.
Please email me too. Thanks.
Hi Jon,
email ready for firmware update
Hi Jon.
It should work now. I've tested it.
Sorry for the hassle.
And thanx,Staaled
Hi Jon.
And thanx,Staaled
Battery power supply
Hi Sugarn,
I've done it! I've build a battery power supply with two 12V 7.2Ah batteries, automatic loader, over charge protector, general protector and automatic switch, and manual switch.
Both supplies are installed, so regulated supply +8V and -8V for the analog stages, and the unregulated 12V for the digital circuit.
It's in an identical case as the player but with a custom made face plate. This just came in this morning and is not yet installed. I'll have pictures posted later.
All caps in the regulated supply are BG's (Standard and N's). It's still running in, but innitial sound is already a big step forward, what a depth in sound stage. Previously I switched now and that from upsampling to non-upsampling because on some discs I found the sound to upfront to harsh, that's completely gone now. Really relaxed and analogue sounding player with plenty of sound stage and detail. Very smooth top end and pronounsed bass.
I can switch the supply to load by hand or it will automatically switch to load after putting the player into standby mode. It will also switch on again after the player awakes from standby.
I'll post pictures this weekend.
Anyway, thanks for your help, after you discription it was very easy to connect the battery supply.
Best regards,
Saffier
Hi Sugarn,
Best regards,
Saffier
Hi Saffier,
Good to hear that you've successfully installed linear PSU and you're happy with the result.
I'm planning to try replacing opamp output stage with tube output stage. Maybe it will improve sound to more analog and more hi-end.
I'll post the result when I'm done.
Output stage
What do you think of these?
http://www.machmat.com/sales/kits/pre/tubeoutput.htm
They are on my list for future upgrades.
Saffier
Saffier
Hi Saffier,
That kit should work well, easy to build. But I will build my own with my stock tubes. I have a lot of tubes to find out which tube sounds best. I will try EC8010, E83F, E810F, 6DJ8,12AX7,6922,5687 etc..
If you need OSCON caps for you mods/upgrade project, check the Market Place/Trading Post. Just to let you know, I was able to get a lot of these caps at a much better price than from the normal seller. These caps are new.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=63249
I ship worldwide. I shipped to USA and Europe so far.
Bye...
Bye...
963SA firmware
Hi all,
Just recently got a second hand DVD-963SA and have been enjoying it.
I am interested in upgrading to the latest firmware. I found the French site which has the 4.81.25 firmware, and I downloaded and installed in last night. However, I still have the original servo firmware version of 7.10.0. Is there a version available that has both the .25 firmware and the 7.12.0 servo update?
Or, would it be more desirable to go 'down' to the .24 version to get the 7.12.0 servo version? I am most interested in improving audio performance and disc reading capabiliities. All thoughts are welcome, if you have the 7.12.0 version that can be applied seperately to my .25, please contact me via PM.
Thanks!
Sam
Hi all,
Thanks!
Sam
Service Information
I have just purchased a non-working 963SA. Could someone please tell me if a schematic is available in the public domain, and if so where it may be found?
Thank-you,
Fred
Thank-you,
Fred
Firmware Upgrade
Hello Jon,
I have my 963SA working. Could you please E-mail the firmware update? My E-mail address is fred_troy@hotmail.com
Thank-you,
Fred
Hello Jon,
Thank-you,
Fred
Has anyone installed the tentlabs clock upgrade yet? I see it's available in the US from hotrodmods.com
upgrading output stage of 963sa
Has anyone out there tried adding the Musical Fidelity X-10 V3 or Decware Z-Box stage buffers to the output of their 963sa? I'm cuirous if either brings any benefit. I realize a new output stage with tubes would be best, but I lack the know-how to design/build something like that and wondered if one of these commercial units might get me part of the way there.
Chris
Chris
output stage
Hi Chris,
Both options are no output stages but output buffers, so you still have the opams in the circuit. The output buffers just make the output impedance match your pre-amp better.
The best way to upgrade the output of the 963SA is to exchange the opamp to the AD8066 or the like...or plug in a tube output STAGE, see http://www.machmat.com/sales/kits/pre/index.htm then sellect TUBE OUTPUT.
A third option bypass the opamps and plugin some exotic transformers (Audio Consulting), so you will have passive amplification.
The last will sound the best, but also the most expensive.
Rgds,
Saffier
www.picturetrail.com/s.brull
Hi Chris,
Rgds,
Saffier
outpute stage for 963sa
Thanks Saffier. So, if I wanted to use one of those kits to upgrade my 963sa, I would need to order one of the Stereo single ended output module, and one of the Resistor coupled power supply for the tube output stage; is that correct? If I order them fully assembled, how difficult would it be to attach this system to the 963, i.e., what would be involved? Is this something that someone like me who has replaced the signal path cap's with Blackgates on my 963sa be able to manage, or is it fairly complicated?
Chris
Chris
- Digital Source
- Upgrading Philips DVD 963 SA
