Got a Behringer UMC1280 to do some multichannel DSP, so revisitng this project. I concur in earlier posts that the mids on the speakers seem to be reverse polarity. So double checked, not sure if I switched in wiring or not, but measurements confirm mine seemed to be reversed in MY setup (yours may be different). I used REW to measure the waveguides, and here are some of the results:
First shows the frequency responses. (Red) according to schematic, (Dark Green) mids reversed. There is a dip at 1.8khz vs with mid reversed, so I assume that confirms its 180 out of phase. Then progressive levels of stuffing, it drops the frequency repsonse on low end, so a peak filter at 1.2khz can take care of that.
This shows unwrapped phase. Something odd going on with red, vs. green which is smooth (mids reversed). So I think this is the way it should be and are leaving the mids reversed from what I had.
Here's the harmonic distortion. With the original, there is a spike, mids reversed (green) it goes down. You can see the effects of tuning with stuffing. Ideally, I would get this right, then tune each one individually using the DATS V3 and looking at the impedance graph. So despite the lower frequency drop, the overall distortion is at its lowest.
At this point, REW suggests a 1.2khz -4db filter.
So this is where I started orginally:
And this is where I ended (flipped mids and adding 1.2khz, -4db crossover):
I think I did it right. Quick directivity plot around 0 - 45 degrees.
First off: it's so cool seeing people build things I designed! I should do this more. I'm terrible at finishing things, but you guys aren't.
In regards to the distortion, keep in mind this waveguide was inspired by @bwaslo 's speakers that I bought, and it uses the same midranges. They're made by Gento and they're ridiculously inexpensive. It looks like the stuffing reduces the distortion from 5% to 0.2% , which isn't too shabby for a driver that costs about $1-$2.
I know that's insanely cheap, but there was a method to my madness:
1) the first one is that I've tried a LOT of small midranges, and dozens of the good ones are no longer available. For instance, bwaslo considered the Aurasound Whisper for his project, and I used them in my first Unity horn, 21 years ago. But the price of the Aurasound is all over the map, anywhere from $8 (back in the day) to $35 today: https://www.madisoundspeakerstore.c...7TovtbIIoaIu5hoJVVwn7cMhMMm4x_zr3heKjUsMuA1MM At $32 for four of them, they're compelling, at $140, you can do better. Possibly the best thing about the Gento isn't the price, it's that it's available all over the world.
2) It took me a few years to figure out some "cheats" to squeeze larger mids onto a Unity horn. At this point, I can reliably get 3"-4" midranges to work on a Unity horn. But it's tricky and I was hoping to put a design out there that was affordable and relatively easy to work with. For instance, I once made a Unity horn using a single 8" woofer and a compression driver. And it kinda worked. But it was definitely pushing the limits of what is possible; it had to use all kinds of byzantine tricks to make it (sorta) work.
I'm kind of prolific when it comes to "making waveguides", but the crazy thing is that 25% of my projects never get posted. Basically I'll make a waveguide in 2-4 hours, print it, measure it, then forget about it for one reason or another.
This is one of those; I don't think I've posted this. If I'm wrong, apologies for the double post.
- Patrick Bateman
- Forum: Multi-Way
Have you tried plaster of Paris? It’s much thicker and would probably be better with no infill, but it won’t leak.The gyroid infill was awesome to allow the epoxy infill, unfortunately, the print leaked the epoxy through some voids.
Saw it being done by that YouTube channel with the British guy a few months after what I did with the laser speakers. Much cheaper to do that what I did. I presume a more watery mixture would be best. Epoxy allowed me to sand or drill and tap the speaker holes.
I have experimented with filling 5% gyroid infill prints with the plaster of paris method and filling them with fine sand. Plaster of paris is a mess i just didn't like and i feel like sand is moving a little bit under vibration. I thought about infusing the sand with some vegetable oil but i don't think its any less messy than plaster of paris 🙂
In the end i will mix sand, PVA and plaster of paris, as i found plaster to still have some ringing left.
Does the epoxy get hot when it cures? If leaking is the issue then coating the print prior to filling would work. I would prefer epoxy over plaster, I just thought it would get too hot as it cures. I tried to fill with epanding foam once and it melted my horn so I stayed away from anything with heat.Saw it being done by that YouTube channel with the British guy a few months after what I did with the laser speakers. Much cheaper to do that what I did. I presume a more watery mixture would be best. Epoxy allowed me to sand or drill and tap the speaker holes.
Doesn’t get hot at all. Just get the crystal clear casting epoxy for slow cure. I would print it, then pour a gel coat over everything, get all the nooks and crannies. Fill it with water to test. Any final leaks, just put modelling clay or plumbers putty. Then fill it up. Once done, water base putty will wash away.
- "Unitized" Image Control Waveguide
