I'm have to look but there is a UL rating, remember this stuff has become popular for solar installations and I suspect there is enough money involved to make a UL submission to meet codes for large series PV installations.
Apparently the code has changed. Welding cable now requires a 600 volt rating. There is a class for battery cable that can go as low as a 30 volt rating!
Reminds me of the folks who made speaker connector adapters to allow you to use regular extension cords, the very next electrical code update banned them.
Try 1mm siver in PTFE sleeve with an air gap, beats anything else Iv'e tried. In the UK we call pure silver (FINE) don't use stirling silver
Why?
could that be to withstand the arc/spark initiator which is a higher voltage HF than the normal welding voltage?Apparently the code has changed. Welding cable now requires a 600 volt rating. There is a class for battery cable that can go as low as a 30 volt rating! ........
My wife needed new speaker cable for her Klipsch Chorus
I went to Home Depot...bought 50 feet, of 16 AWG, 2 wire, Bright/Safety Green, extension cord, and cut it in half.
I installed Banana Plugs on the ends.
The music sounds fine to me.
yeah, if you can wait the 350 hours for the thing to break in!! 😡
The popular snake oil sales pitch is "burn in".yeah, if you can wait the 350 hours for the thing to break in!! 😡
Don't forget that wire is directional, so the whole process can get messed up if one channel is wired backwards😀
No kidding, this used to be a thing
watch out from leaving one end of the wire disconnected while the other end is connected and driving it. Electrons are known to spill out from the open end, thus affecting the quality of the wires.
True story!
True story!
It's funny you should mention this idea. I built an electron trap using 24k gold leafing sheets, wrapped over a wire grid like a kite. The gold sheets capture the electron spill at the end of the plug, which I redirect back to plug using a 22 awg copper wire. The 24k panels are positioned similar to a segmented aperture radar horn. Incidentally I could see this phenomenon over a scope. But the end result is a nice up tick in Sq.
True story!
Time to revisit the old Charles Rodrigues Stereo Review cartoons - or the Audio Magazine Lirpa Labs reviews
The two main reasons for differences in sound character at the extremly wide range of speaker wire (both at homebrew resp. diy cables so as commercial available cables) are the fact, that there is no an individual positive cable and no an individual negative cable for each channel present at the most cable versions (i. e., there is mostly a capacitive character present) - additional most cables don't consist from one or any few solid core wires, instead this there the inner conductor is made up of many individual very thin wires that in turn have been twisted together to form bundles and thus produce a cable, which is extremely flexible and thus easy to lay.This system is an overkill .... just heavy copper wire .... and if you are afraid of signal refexions and other dtufff just put a 0.047 uF cap with a 22 ohms resistor at the far end of the wire to make a termination.
Both is a great disadvantage for good sound quality. But for the last fact I don't know the real reason.
Under
http://www.diyaudio.com/forums/part...egative-wire-overview-wanted.html#post4941398
maybe I will find out many commercial available cable versions without this mentioned disadvantages.
All cables have two separate wires for pos and neg... this reaks of audiophoile myths and rubbish as the links do on the other thread you have linked to. If a speaker cable has a sonic character then your system is well naff, the cables do affect the signal but at a level to low to be audible unless the cable is badly engineered...
Pure nonsense.The two main reasons for differences in sound character at the extremly wide range of speaker wire (both at homebrew resp. diy cables so as commercial available cables) are the fact, that there is no an individual positive cable and no an individual negative cable for each channel present at the most cable versions (i. e., there is mostly a capacitive character present) - additional most cables don't consist from one or any few solid core wires, instead this there the inner conductor is made up of many individual very thin wires that in turn have been twisted together to form bundles and thus produce a cable, which is extremely flexible and thus easy to lay.
Speaker cables with widely spaced conductors have high loop inductance. So when used with loudspeakers that have low impedance at high frequencies like true ribbon speakers (Apogee) or some electrostatic speakers, the high frequencies will be rolled off.
The physics of cables is well understood since at least 60 years ago. The dynamic of audiophile brain-wallet-hand coordination and its affect on the ear brain system is much less well understood, but susceptible to sleazy manipulation by technical-sounding advertising, superlatives and other such tomfoolery.
Why are we talking about this?
It seems to be extremely well understood by those who make their living from it. Part of their technique is to ensure that it remains poorly understood by their victims.Ron E said:The dynamic of audiophile brain-wallet-hand coordination and its affect on the ear brain system is much less well understood,
- Member Areas
- The Lounge
- ultimate speaker cable design diy
