ultimate speaker cable design diy
PaleRider said:
Legends says that this or that kind of wiring should be "sufficient" meaning it will not overheat and burn off.
If you think our criterion for speaker cable is that is does not melt then you do not understand that which you criticise. Of course, this is a standard 'debating' trick used by people with no facts on their side: criticise something which people do not believe; so much easier than dealing with the issue.
1: When it comes to wiring; what might be sufficient on the primary side will be a restriction on the secondary side.
No idea what you are talking about. OPT wiring? If so, blindingly obvious.
2: Music is all about dynamics. Dynamic headroom is a keyword. (sounds easy)
Not true. Music is mainly about frequency and time - what note was played when? How loud also matters, but is less important. In any case, what has 'dynamics' got to do with speaker cables? (Unless they are nearly melting)
If we limitate the current-flow in a system we might still not burn off or even heat up the speaker-wires, but the system will sound "thinner". A lot thinner. A frequency-test will show exactly the same result.
Nonsense. Two sorts of nonsense. Resistance does not limit dynamic range; it affects quite and loud passages equally. Resistance actually affects frequency response, as speakers are not constant loads.
To make this story short; even the smallest amount of serial resistanse will reduce a systems dynamic capacity. This will be most audible in the lower range since this is where the power is needed. (ever noticed that your amp`s meters "follows" the bass-rythm?)
No.
The thinner wiring will make your amp perform like if it was weaker, smaller and not capable to run your speakers. And you might never get it because you have never tried to run real sufficient** wires.
Almost true, but sort of false too. Speaker wiring which has a resistance equal to the nominal speaker impedance will drop the power by about 6dB - so the amp will seem weaker. 6dB is not a big drop in power, so the user will barely notice the power drop. He will notice the disturbance in frequency response, but in some cases may even prefer it!
Speakerwires should be kept as short as possible, (max 3 meters) not stranded/twisted or any other "configuration" but thick and solid*, **fun begins at 9awg. Solid core copper, + and - separated.
* speakerwires must be seen as an extension of the power-amps secondary circuit, as well as the speakers internals. How many designers seems to have grasped this?
Btw; if there is any kind of multistrand-wiring in your equipment ( like ac-intake to powerswitch) you might do some easy upgrading.
Short as reasonably possible, yes - because there is no reason to make them longer. Stranded or solid does not matter for electricity, but stranded cables are more flexible to easier to install or move. Designers have not "grasped this" because is it not true. The reason OPT secondaries use solid cable is all about mechanical stability and nothing to do with sound, so no harm whatsoever in continuing with flexible cable.
Is someone offering a prize for the post containing the most audio myths?
Ellipsis (plural ellipses; from the Ancient Greek: ἔλλειψις, élleipsis, "omission" or "falling short") is a series of dots (typically three, such as "…") that usually indicates an intentional omission of a word, sentence, or whole section from a text without altering its original meaning.
Somebody suggested thicker cable is better for speakers, I gave it a try, I must say that regardless of sonics, it is quite inconvenient...
heavy-duty-steel-wire-rope-sling-safety-anchor-shackle-bolt-construction-site-32466662.jpg
Later, I experimented with very thin wires. I couldn't discern much difference, though it must be said that a crane isn't usually necessary for proper handling. That's a benefit, as far as I can tell.
p7134140-jpg.10172
#0000 welding cable flexible and readily available .000025 Ohms/ft. Any contractors outlet has suitable bolt on terminations at ~$11 @.
The limit on welding cable is the thin insulation! Typically rated for less than 100 volts and sometimes as low as 30! Some idiots use it for lighting feeds.
As to the resistance of a loudspeaker cable it should be less than 5% of the minimum loudspeaker impedance. The minimum impedance can be as low as one half of the rated impedance.
Now with marginally stable audio power amplifiers the loudspeaker wire can have a real influence. So if increasing the wire spacing in a cable has an effect I would look at the audio power amplifier. If you wish to reduce the charafteristic impedance of the cable the wires should be close to each other.
Now twisting the wire helps to reduce EMI pick up.
I use long cable runs on my systems and cable construction can become an issue. Mostly from the standard approach ignores all the secondary effects of the system.
I just run lengths of bellwire inside an outer shell of thick rubber garden hose . Sounds fine and impresses my "audiophile " vistors when they see my seemingly enormous and obviously expensive cables snaking around the floor . 🙂
If you are truly OCD, and having fun experimenting you can try the following:
Flatten your 1 mm silver wire in a pasta machine or have it done at a local machine shop. Solder it to solid wire to pass into the teflon tubing. Proper diameter will allow just the edges of the wire to contact the teflon.
This theoretically accomplishes two audiophile holy grails...mostly air dielectric and maximizes surface effect.
It is also a hair shirt fragile set up so beware. I'm not sure I could tell a difference, but it was a fun project. (Next project is the Pass vfet amp... awaiting the build guide and parts)
Mine says 600V.
#4/0 (AWG #0000) flexible fine strand welding cable. Dual jacket. 600 volt AC or DC rating. Only Red & Black are stocked in 3/0 and 4/0 cable sizes - other colors available on special order at higher cost (2-6 week lead times). Minimum order on this item is 5 feet per color.
I did once score a reel of 25mm tri rated switchgear cable from a lab we were building. I used to make roving jump leads off a gert big UPS battery that was otherwise going in the skip. I did think of making some speaker cables out of that but was very silly. Gave it to a mate with a garage in the end and he was chuffed to bits with it.
I also dallied with the idea of Anderson connectors...
Originally Posted by JMFahey View Post
Nonsense.
ANY conductor is flat down to DC by definition , there is no Bass deeper than DC, so conductor type or material can NOT affect Bass depth at all.
IF you claim to hear otherwise, fine, but attribute it to subjective opinion.
Well you are sufficiently arrogant, mybe even a bit over the edge. And you are wrong too.
So you attack my *personality* .... I´d rather prefer you attack my *Physics*
Show me a conductor which has higher/improved/better/different frequency response at low audio frequencies or shut up.
I mean *measured* different. 🙄
