This is the first time I took advantage of room reflections instead of trying to treat them or mostly work around them.
I like the idea of working this way with room reflections. I plan to try some channels to increase the ambient sound, I tried it before, there are positive effects, I want to return to this topic!
I've been enjoying my open baffles for some time now, paired with monopole horns.
I wanted to try something very small in comparison, and have gone with each sealed floorstanders using sidefiring MarkAudio 12P and 12PW in dipole use. Better bass from a sealed cabinet, using room reflections to fill it, along with a tweeter aimed at the listener from the null, using a very high knee and a shallow slope to provide location cues.
It's daft, but it works. Decent bass and no noticeable cabinet resonances, even before internal damping.
It becomes very impressive when crossed to a single sealed sub.
I like your ideas here too. It's fun to go outside the norm. This is the first time I took advantage of room reflections instead of trying to treat them or mostly work around them. My only concession is using a tall planar tweeter to limit vertical directivity, which in this case I like better than dome domed and a ring radiator tried in this experiment.
It's not open baffle, but is conceived from wondering how to make my dipole pair better.
This reminds me of an aquaintance who use two pairs of Quad ESL989s with one pair positioned normally and the second pair placed behind, side firing.
The Bitches Brew Open Baffle Live Edge Speakers
Stunning Imaging + 120dB Dynamic Range + Natural Wood Finish. Named after Miles Davis’ classic 1970 album.
I’ve been designing speakers for almost 40 years as a hobbyist, including a 3 year stint at Jensen’s OEM automotive division, where I designed speakers professionally for Honda, Mazda, Chrysler and Acura. I’ve built just about every type of speaker and enclosure type that exists except electrostatics.
This system embodies the best of what I know. An “ultimate design” which also aims for simplicity and elegance. 15” 3-way system with 2x SB Acoustics 15OB350 woofers and 1x B&C 15CXN88 constant directivity horn coaxial.
These are made from book matched slabs of spalted birch. I picked out the wood at Schroeder Hardwoods in Harvey Illinois, and Seth Cothron of @studio38designs performed the carpentry. Spalting is when fungi has grown in the wood, and in right proportions dramatically emphasizes the grain.
If you’re willing to spend $25,000 to $100,000 retail you can get some pretty extraordinary speakers. Nevertheless at about $4500 including all parts and carpentry fees, these speakers perform feats no commercial speaker I’ve seen of can do. These put some of the most respected designs in the world to shame.
Achieving flat frequency response is of course important. But just accomplishing that is the junior varsity team. Today with modern crossover design software and DSP, anyone who can’t achieve that isn’t trying. What separates the men from the boys in speaker design is how many other priorities you can simultaneously achieve.
When I have friends over they are in awe at the transparency, realism, impact and imaging. They have the accuracy of a KEF or B&W, the dynamic range of a Klipsch, the impulse and phase response of a Duntech, the transparency of planars and imaging better than all of the above. Most people have never heard sound like this.
Frequency response in real room, mostly at listener positions, averaged across both speakers and 16 locations:
I chose Open Baffle because nearly all “box” designs sound… boxy. Most people have never heard a speaker that doesn’t sound boxy! But once you have, it’s like experiencing “real” Chinese food or Italian food for the first time. After the real thing, you’ll never again be satisfied with Panda Express or Olive Garden. Same thing here: they have a huge sound stage, an open, effortless, spacious image and a palpability that must be experienced.
Open Baffle speakers have almost no radiation to the side and that gives you many interesting possibilities in room placement.
Most people have never heard a speaker that has “dynamic range to burn” - i.e. can easily exceed 120dB even if you never turn the volume above 90. Most people don’t realize that even the most expensive and reputable speakers put out bucket loads of distortion at many frequencies and really don’t have much dynamic range.
You probably haven’t heard drums until you’ve heard them this way. Bill Duddleston of Legacy Audio says, “If you can see the cone moving, it’s distorting.” With 3 15” cone surfaces, you have to get well past 90dB before the cones move visibly. Distortion is incredibly low at any reasonable volume level so compression is negligible.
High efficiency: They’ll play as loud as most people want on a flea-watt amps. My amps are 60 watts per channel (bi-amped, 4 channels total) and I can’t drive them into clipping with any of my albums at any sane listening level.
This design simultaneously prioritizes additional things:
Constant Directivity across the entire audio spectrum. This provides amazing precise imaging everywhere in the room - even when you’re literally standing right next to one speaker! You can walk all around the room and the stereo image is stable. You’re not confined to one sweet spot, and in fact one of my favorite things is to invite a half dozen friends over, sit them all around the room and listen to an album together. There is not a bad seat in the house.
Most people have never heard a speaker that can do this. Constant directivity says that the speaker gives flat frequency response on axis but also as you go off axis, the level drops off evenly (and not only at the top of the woofer’s and tweeter’s range) so the response is still smooth everywhere else. When combined with proper speaker positioning it sounds great everywhere. At 45 degrees off axis, the level drops 6dB and at 75 degrees it drops 12dB. 90 degree side radiation is down 15dB or more.
This is nearfield frequency response at 0, 15, 30, 45, 60 and 75 degrees off axis. (I don't have a good way to measure these at low frequencies, so there is odd behavior below 150Hz in the nearfield that is not present at greater distances):
Some of the finest horn and studio monitor designs achieve constant directivity above 1000Hz, but this system achieves Constant Directivity across the entire spectrum.
Linear phase further contributes to incredible precise and stable stereo imaging. It also delivers incredible attack and slam with percussion because the wavefront is incredibly steep with no phase inversions or delays. This is a huge key to soundstage and it enables you to resolve very fine details in recordings that were previously obscure.
Below is phase response at listener position, averaged at 5 locations around my couch:
Below is impulse response:
Below is Step Response:
As you can see, the impulse and step responses are much better than nearly all speakers.
Specifications -6dB at 19Hz - 19KHz; sensitivity 100 dB, power handling 500 watts per channel; +/-2dB at listener position from 200Hz to 15KHz; +/-45 degree constant directivity; phase +/- 30 degrees from 80Hz to 15KHz.
Sensitivity is 100dB 2.83V/1 meter. Power handling is about 500 watts. Impedance 4 ohms.
Most dipole / Open Baffle designs are mounted on a flat board and the dipole cancellation effect kicks in below about 80Hz. That means by 20 Hz you’ve lost 12dB (-6dB / octave). I added “wings” on this design to counteract some of this cancellation. The top woofer, crossed at 110Hz, operates in dipole mode across its entire range.
Then the bottom two woofers have “cancellation prevention” from the cabinet sides which extends the middle woofer down to about 55Hz before rolloff begins, and 35Hz for the bottom woofer before rolloff begins. This adds significant bass extension while still maintaining the overall dipole sound distribution pattern.
The side wings, then, actually function as a short transmission line, with resonances between 150-250 Hz. By crossing it over at 100Hz I avoid peaks in the upper bass. The low end resonant frequency of the system is about 26Hz.
This is the schematic:
I thought about tri-amping these, which you certainly can do, but I felt it was considerably simpler to use a 2-way MiniDSP 2x4HD (a fantastic product) and bi-amp them, with a very simple 6dB/octave PASSIVE series crossover between the subwoofers and the mid-woofer. It is series instead of parallel because a series crossover has much cleaner interactions with impedance peaks of the woofers.
This however does not create a true 6dB crossover, because the mid woofer is acoustically rolling off at 24dB per octave below 80Hz. So the phase of the mid woofer has to be reversed to prevent cancellation, which you can see on the schematic.
In order to preserve linear phase, I used Eclipse Finite Impulse Response filter software to create a phase inversion “max phase” filter at 110Hz. This is loaded into the MiniDSP FIR function. I also used the FIR filters to linearize the phase of the B&C 15CXN88 woofers at the 1100Hz upper crossover frequency, and linearize the phase of the B&C 15CXN88 horn tweeters at the 1100Hz upper crossover frequency
I have really come to love professional coaxial horns with constant directivity. I used Radian 8” coaxial in my article in AudioXpress and they sound fantastic. A word or two about horns is in order.
I used to hate horns. The first time I heard Klipschorns I thought they had thick, congested bass, ragged midrange, and spitty highs. Yes, I did hear the dynamic range and power, but I couldn’t get past the offensive harsh sound of the horns.
But remember.... that was the 1980's. Many PA systems still sound that way. But horns in the hands of a really good practitioner do NOT sound that way. They sound marvelous. They’re not harsh, and in fact they have much lower distortion than domes and cones. But they are difficult to tame.
Horns almost always have a downward tilt in the treble (especially Constant Directivity horns) and they almost always have more dips and peaks than domes. Domes are very well behaved while horns need TLC. You have to coax the best performance out of them.
If you do that, which is best done with Digital Signal Processing, you get extraordinary dynamic range, high efficiency, and constant directivity. This achieves feats of stereo imaging that conventional speakers in principle cannot match.
Combining IIR and FIR filters to get the optimum crossover
IIR filters are the standard Digital Signal Processing feature in the MiniDSP units. FIR (which stands for Finite Impulse Response) requires special software. IIR is “minimum phase” which means that anything you do to alter the shape of a frequency response curve also has a non-negotiable phase penalty. FIR allows you to handle time and frequency separately, but it’s harder to do.
In this design I did all of the crossover and major response shaping with IIR filters and then added FIR to solve minor frequency response and phase issues.
The tweeters have 80uF capacitors to prevent damage. They roll off below 300Hz so they do not effectively factor into the crossover design. The woofer 6dB series crossover has a very high quality, low DCR inductor (<0.6 ohm).
About the B&C woofer & horn
The B&C 15CXN88 coaxial is a 15” paper cone woofer + 3” titanium compression constant directivity tweeter in coaxial configuration. My measurements are actually better than the published factory specs:
B&C 15CXN88 raw woofer SPL
B&C 15CXN88 raw tweeter SPL
As you might expect, I EQ’d the tweeters with the MiniDSP and the Eclipse FIR software to obtain flat response both on and off axis.
I chose the SB Acoustics Bianco 15OB350 woofers for their high Q of 0.7 and 40Hz resonance as they are designed for Open Baffles. In this design they have a final resonance of about 26Hz. With about 10dB of EQ boost they easily reach down to 20Hz.
Below you see a response curve (front side) with the mid-woofer wired out of phase, so you can see a null at the 110Hz & 1100Hz crossover frequencies.
In Open Baffle designs I’ve always felt that having an OB woofer firing on both sides, but tweeter firing on only one side, never sounds quite right. So I added a SB Acoustics H250 horn and 44CD-T driver on the back. Photo:
I added a small passive notch filter to flatten the response around 4Khz which you can see in the schematic.
Rear response curve:
MiniDSP configuration files: https://tinyurl.com/bitchesbrewdsp (Note: These will ONLY work on the MiniDSP 2x4HD and they are based on measurements of my drivers in my room. Use at your own discretion; all modifications are up to you.)
With 100dB sensitivity for the woofers and 106dB for the tweeters, one of the most important things is selecting amps with low noise! I use Adcom GFA2535s with the input levels turned down about halfway which brings the noise down to below audibility.
These particularly excel with percussion, strings, plucked instruments, horns and aggressive bass lines, including electronic music. There is no music style that these do not excel at, from Bruckner and Stravinsky to Rush and Porcupine Tree. The resolution is incredible. You hear everything and the stereo image is huge. It fills the room and has a palpable sense of space.
The design is copyright (c) 2021 Perry Marshall. You may build these for personal use. Commercial applications require licensing.
PDF for Bitches Brew Live Edge speakers
For those who might be having difficulty with the rendering of pictures in the above post, here is a PDF describing the design.
Perry Marshall
Perry Marshall
Thank you Perry, a job well done and documented!
Two things left me wondering - have you tried switching polarity of the backside tweeter and did you hear a difference?
The more important thing is the listening room- it looks like rather small and well damped... I believe that the sound would excell even more in a bigger and more reflective environment! Please give them a chance to show full potential!
Stunning aesthetics, and very nicely executed design, Perry!
I am just starting to tinker on the beginnings of my first OB speaker design, and this is giving me cause to re-evaluate a preliminary decision not to try coaxial horns (I've had a set of Radian 5208C's awaiting an OB project for quite some time now), but perhaps I'll give 'em another look - would love to learn more about what kind of "TLC" is really needed to get the best from a CD horn coax. Is there something specific you would look for in a coaxial driver which you think makes for good raw material to work with (or traits to avoid)?
On the bass end of things, I've been revisiting some of John Kreskovski's (now archived) articles on cardioid pattern LF design, and considering going towards a stuffed U-frame type of LF design rather than the fully open style U-frame that you've selected here. Part of my rationale is an aesthetic / dimensional one, in that I want the speaker's total depth to be no greater than necessary, so I'm reluctant to build the rear wings as deep as you have - a compromise, perhaps, but one that I'm willing to attempt, at least initially.
Anyhow - fine work. Thanks for sharing!
Thank you, great project, great report!
I can't say that I feel that this sounds not right, but I want to make one more try to integrate back firing tweeter, you reminded me about that idea!
The rear horn in in "correct" polarity already, but frankly I don't think it makes that much difference other than whether there's a hole in the response from cancellation with the woofers.
The listening room I have is the one I've got... but there is no question that these will really open up in a larger spacious more reflective room.
I made a GREAT system using the Radian 5208's and you should not be afraid of them. http://www.tinyurl.com/liveedgedipoles
Feel free to use as much of this design as you want. When I say "tame" I mean:
-Horns have jagged frequency response patterns so especially with passive crossovers the designs can become quite a bit more complex. You also have to compensate for the downward-tilting response.
-Depending on the situation you may also have worse phase issues with other drivers than you have with domes.
DSP makes it a LOT easier to deal with this stuff. Especially the time delays. Frankly I don't think that basic IIR DSP is all that hard to use in fact for all practical purposes it's much easier to execute than passive crossovers.
You don't need FIR DSP (which is the deep end of the pool, much more complicated). If you have a MiniDSP 2x4HD with one channel for the Radian woofer and the other for the coax tweeter you can make a fantastic system. Note that the 5208 woofer in OB is really a midrange and won't take you much below 100 Hz. The Radian 5208C would also sound very good in a transmission line and probably go down to 50.
If you fix the frequency response anomalies and get the timing lined up they'll sound fantastic.
Also known as a Hartley Boffle.
http://p10hifi.net/tlinespeakers/forum/HiFi-Boffle-Article.pdf
dave
Ah, nice! That looks very close to what I had in mind... a single 15" for the low range, and something full range or mid/tweet up top.
For the horn tweeter, if it's just a matter of flattening the tilt, and knocking back a few peaks, that doesn't sound too difficult. Normally, I wouldn't chase after all the jaggies in the upper treble... but, something to play with and see I guess.
I recently got a nanoDIGI 2x8 for prototyping the XO. Since I do spin vinyl on occasion, and have other analog sources, I had been thinking I would ultimately implement the tuned XO in analog form... but we'll see just how much complexity is needed. So far the nanoDIGI is proving itself quite easy to use (now if only I could get the darn IR remote to toggle inputs for me...). I don't think it'll do FIR corrections, though.
I've just procured a pair of Eminence Kappalite 3015LF for the low range, and had been thinking of crossing over to the full range or mid/tweet combo at around 200Hz or so. Somewhat lower Qts (just shy of 0.5) than typical for OB, but Jim Griffin seems to have had good success with them, and... isn't that what EQ is for!?!
Thanks for the link to your other article... I'll definitely give it a read.
So... you're saying it's been done before?
Just how many of these toys we're playing with weren't already invented in 1954, I wonder?
Originally Posted by Klimon View Post
Never happened to me.
We welcome you
George
Thanks George. I guess you got my joke, or are just faking it. Anyhow, I couldn't tell the difference.
If you can't tell the difference, fake it. This can become recursive. And annihilate the universe.
Alright, so I dragged the Radian 5208's out of storage... apparently, they're the older "B" rev, not "C", which tells you something about how long I've had them squirreled away...
Wanted to get a look at the compression domes to see what size and material they were, and was surprised to find when I opened them up that the compression chamber has no damping material in it. Now, Radian surely knows what they're doing, but still, I'm thinking it might be a good idea to mod these with some kind of damping material to help squelch any chamber resonances before I set about measuring the speakers and fiddling with EQ stuff.
The other rather disappointing thing I noticed is that whatever material Radian used to cover the rear label, it is some kind of soft clear polymer, and it has taken a set while in storage, picking up all the wrinkles of the plastic bag it was wrapped in! Not too thrilled about what that has done to the aesthetics, but at least it shouldn't affect the performance, and if I'm lucky, maybe they'll relax back to a smooth flat surface over time.
So the question is: what to put in the compression chamber, if anything, for damping? Some adhesive-backed felt, perhaps?
Has anyone tried this, and did it make a worthwhile difference?
I use adhesive-backed felt with RCF940. A very simple tweak. However, the experiment was not clean, at the same time I done the papier-mache cover for membrane. Together, these two tweaks worked well in my opinion, the top became cleaner and softer, without any artifacts in the measurements. My friend also noted the effect (he had an RCF950 and he knows the sound well).
- Ultimate Open Baffle Gallery
