Ultimate Open Baffle Gallery
thanks nicoch58. I'll use an active configuaracion, with vst crossover. the extra power and SPL of kilomax, help to offset the low rolloff. in terms of different sensitivities I have only to properly adjust the gains of the amplifiers properly.
At normal listening levels I do not think I get to have a problem with thermal compression
I'll do all the processing before the DACs and all without phase distortion
sorry Kjeldsen
Here a photo of a beautiful open baffle😀
Hello Sumanta,
they look nice. Can you tell us more about?
Well I had used Philips HiQ paper cone 8" driver for mid, another paper cone 3" driver for tweeter facing up.
All drivers except tweeter are dipole and placed in open or open-folded baffles.
I had made Ripole cabinet with Ahuja drivers of 15" size - AS15 X 200.
I have active crossover and two amp to drive them. Cross over is of 4th order at 170 Hz.
This is a link to my setup playing a Vikram Ghosh & Pete CD, Kingdom of Rhythm.
https://www.facebook.com/1689741724600319/videos/1734114773496347/
hi, silverprout!
Fountek midbass? (5" or 6"?) are you satisfied?
Yes satisfied (6"), but i use it only it on the 120Hz to 2.2KHz range (HP active LR24 120Hz and passive LP18@2.2K) in a heavy stuffed closed box (5Liters).
Very, very clean midrange... a 8" should be a tad better but needs a bigger baffle and can't be crossed higher than 1.5K.
I'm still searching for a cheap tweeter (HP@2.2KHz) for replacing my good old vintage audax collector.
