Ultimate 4U 500mm Chassis - Who is interested?
Base Plate Option
  • Standard Aluminium 3mm or 4mm
    Votes: 5 23.8%
  • Aluminium + Custom Perforated Steel Base Plate 470mm to 480mm
    Votes: 16 76.2%
  • Total voters
    21
  • Poll closed .
The 480 mm width perhaps has some positive qualities.
It would also eliminate compatibility with the deluxe front and rear panels with pre-drilled holes, plus the standard top and bottom plates. I don't think it would improve the heat dissipation capacity very much.
On the balance, I don't see the extra width as being worth the cost / hassle.
Hi pico, this is all starting to get messy, will you carry on or will the store eventually have it - you need to sort it out with Jason, so all who have showed interest in the enclosure you first mentioned, know where they currently stand.
I agree.
I really have no idea, at this moment.
I guess I just need to know how many people are actually interested in building something that is close to perfect as possible or whether they're happy with something that is off the shelf.
I guess I could do it myself and get it made using Australian companies.
I have no idea.
I think I would need at least 10 people that are interested.
I was kind of hoping we could work through this together as a group so that we cover all bases, and everyone felt their needs were taken care of, or at the very least people felt happy with any compromises that might be necessary.
