UGS Power : it's U.P.
..update:
it's ok François i checked the HCFR forum and put myself on the list there.
If a GB is created here i can always transfer my request to this one.
My UGS preamp is going to have a gorgeous business end !!!
Thanks for outstanding work and generosity.
Yeah thanks, personally I can't see what was wrong with the old ones🙂
Does any one know if its been offered here on diyaudio? If not does anyone have a link on the french forum, I hope with a bit of Babelfish action I might be able to place an order and hope no one asks any questions in french🙂
Hi all,
Some minor changes, mainly on the softstart board, to avoid potential problems with heated resistors on faultly reset due to µcuts on mains (lightning induced effects) 🙁 All is safe now 😉
Updated links :
Schematics :
http://psykok.homelinux.org/diy/UP/V2/UpSchemasV2.pdf
Stuffing and drilling :
http://psykok.homelinux.org/diy/UP/V2/UPStuffMecaV2.pdf
Gerbers:
http://psykok.homelinux.org/diy/UP/V2/GerberUPV2.zip
B.O.M. (english version on the second sheet)
http://psykok.homelinux.org/diy/UP/V2/BOM_V2.xls
And some guidelines for building (sorry, it's in french )...
Amps : http://psykok.homelinux.org/diy/UP/V2/AmpPassAPasV2.pdf
Supplies : http://psykok.homelinux.org/diy/UP/V2/AlimsV2.pdf
Vu : http://psykok.homelinux.org/diy/UP/V2/VuV2.pdf
SoftStart : http://psykok.homelinux.org/diy/UP/V2/TriggerV2.pdf
Sorry for that 🙁
Zen Mod said:
I hate ya Frenchie boyz 🙁
besides other things - you have so many great great comics , and I understand Bahnhof Frenchy .....
:clown:
Well ... I am happy to be proud ...
But I must admit that in case of UP and comics : me is nothing...
But mebbe you mean I should get the credits for "other things" ...
Manu
Cheff, Ive ordered the pcbs from the the french groupbuy.
I have a couple of Antek 400VA 20V torroids and Im simulating in duncans psu designer what the voltage will be. It seems that I may get close to 50 V on the voltage doubler end of things. Should I use 63V caps or will it be safe?
Luke,
I was just asking since the output voltage is lowered when the doubler is loaded :
From my 18V trafo, I measure 50V on the doubler unloaded, and 36/37V when loaded.
Thus, for your 20V AC input, it should give around a theoretical 55V (20xswrt(2)x2-Vdiodes) unloaded, so I think you should be safe, but try a sim with a loading resistor in order to draw 60mA.
And prepare to be surprised by the ripple 🙂
