Question for Alex: I'm building one of these for a friend in France (DrizztDo), and have 2 sets of boards from him. I may build one for myself for use in the US (115Vac). I noticed that the main power supply board PCBs that I have appear to be laid out for single primary transformers (230V). Was this board redesigned at any point to allow dual primary transformers? What boards comprise a set for this group buy. I may be interested in a set as well, and will put my name on the list once decided. Thanks!
BTW, I've been reading the homecinema.fr forum, specifically the UGS Muse thread and you guys have quite a forum there. I'm impressed with the level of projects done there.
Add the gain stage to the list, it helps Alex_twn keep track of the requests.Oneminde - count me for 1 pair please
Add the gain stage to the list, it helps Alex_twn keep track of the requests.Of does who have signed up for a new batch of UGS-Muses, who would like to equip their pre-amp with an official PASS gain stage ?
(use this post to add your name)
jacek_k_wawa - 1 pair
emyeuoi - 2 pair
The list so far - edited it to help keep track of requests.
Twitchie : 1-2 PCB sets + gain stage (if offered)
Guyisme : 3 MCU + L/R PCB
Gionag : 1 PCB set ?
Fencki : 1 PCB set ?
Mensing : 1 PCB set
Itsallinmyhead : 1 PCB set + gain stage (if offered)?
Kk74 : 1 PCB set
Fabian85 : 1 PCB set ?
Eriksson : 1 PCB set ?
Myl : 1 PCB set + 2 gain stages ( if offered )
Ernesternest : 1 PCB set
Norgaard : 1-2 PCB sets
Dennis Hui : 1 PCB set
Astromo : 1 PCB set ?
Oneminde : 1 PCB set + gain stage (if offered)
Stanney2017 : 1 PCB set.
Stones : 1 PCB set
schultzsch : 1 PCB set
HelmutHolz: 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
Adams_Leo: 1 PCB set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Emyeuoi : 1 PCB set + gain stage (if offered)
Briangasberg : 1 PCB set + gain stage (if offered)
Jacek_k_wawa : 1 PCB set + gain stage (if offered)
Naz : 1 PCB set
vannhoem: 1-2 PCB set +gain stage (if offered)
Hicoco 1 PCB set
unixdeveloper : 1 PCB set + gain stage (if offered)?
lancer: 1 PCB set + gain stage (if offered)
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
thats why i am asking! there is a phrase „... if i am correct...“
I just checked and yes Éric is right this is R29 - 32
Fencki : 1 PCB set + gain stage (if offered)?
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
thank you alexI just checked and yes Éric is right this is R29 - 32
Oneminde - I guess there is one more clarification needed. Which version of PCB of your UGS module we will get eventually? This one with SMD trannies or old 2SK/2SJ version? Or both?
R29, R30, R31 and R32 are output resistors. R29, R30 and R31 is located underneath while R32 is located on top for the left preamp. While for the right preamp, R30 and R29 is located on top and R31 and R32 is located underneath.
No they are not, they just help to remove commutation noise.
Rout are on the gain stage on my side. For Ine it is different has he use a different solution.
But true that if the value of those R is too low they will have in impact on gain stage Rout and produce distortion.
Just increase the value to 100k, 1K was a schematic typo.
Hello,
Unfortunately not as I reused the boards here that were designed by Flat for the UGS all inclusive (the full relay version) and this was single primary wiring only.
But those pcb are not difficult to modify, I remember to do exactly what you want to do, with a dual primary transformer by drilling few additional holes on the pcb to accommodate the additional transformer pins.
Or maybe someone can redesign those PCB, they are super simple, single layer, with kicad I guess half day max work but sorry I don’t have time myself to do it.
Thanks for HCFR, yes this is a good forum too
Alex.
That part is up to Alex_twn - I just sent the files to him so he gets the chance to inspect and consider his next move. I see no reasons why both can be available or included. The SOT-23 N-chn. version was developed to be more future proof and less costly than the TO-92 style. Jfets conduct in both directions so I saw no issue with that version and the 2SK209 has comparable performance.Oneminde - I guess there is one more clarification needed. Which version of PCB of your UGS module we will get eventually? This one with SMD trannies or old 2SK/2SJ version? Or both?
The adapter board comes via Ine and I guess its only fair that he has a say about that part. He did mention that he is working on a new version for the output capacitors - so unless he is against sharing the adapter board with the rest of us, things are looking kinda decent.
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
HelmutHolz: 1 PCB set + gain stage (if offered)
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
Updated:
Mensing : 1 PCB set
Kk74 : 1 PCB set
Norgaard : 1 PCB set + 2 gain stages ( if offered )
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
I think it's time for some clarification / recap on what the set's will consist of - is it:
"Gain stage" = 2x UGS4 modules making one stereo channel?
1 PCB Set, e.g. the entire set of PCB's from the original GB
I'm in a bit of a dilemma as I already have - and thus prefer, the J109/k389
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
Updated:
Mensing : 1 PCB set
Kk74 : 1 PCB set
Stones : 1 PCB set
trung224: 1 PCB set
Awh: 1 pcb set
JoeyDD: 2 PCB sets
Axelcs : 1 PCB set
Naz : 1 PCB set
Hicoco 1 PCB set
the original set with the known ugs module (from previous GB) and additional gain stage (UGS4) if offered will be offered.
that’s my understanding
It has to be a yes for a complete UGS-Muses (all boards) + UGS4 and/or the UGS4x + adapter board.I think it's time for some clarification / recap on what the set's will consist of - is it: "Gain stage" = 2x UGS4 modules making one stereo channel? 1 PCB Set, e.g. the entire set of PCB's from the original GB
J109/k389 are just dual J74/K170. I believe the 2SK209GR (Idss; 2.6~6.5 mA) or 2SK209BL (Idss; 6.0~14 mA) is a good substitute. They are roughly €0,35/pcs if one order more than 10 pcs.
Just kindly beware of not wanting to go too fast or you learn afterwards that these modules wont just functionally perform as per yours expectations.The SOT-23 N-chn. version was developed to be more future proof and less costly than the TO-92 style. Jfets conduct in both directions so I saw no issue with that version and the 2SK209 has comparable performance.
I know what I am talking about because I just designed my own N-JFET only UGS version. It did took me a lot of design trials, hours of spice simulations and 3 PCBs iterations to make mine working properly.
Here it is just how it looks like and a FFT measurement of it (differential measure).
And sorry but please don't , I won't share the schematics, nor will offer at this point this module to be included in this group-buy – perhaps I will later if no objection from PASS Labs which I feel it is required since I started from an UGS4 schematic similar to the one you've got.
- UGS-muse preamp GB
