UCD 25 watts to 1200 watts using 2 mosfets
Disabled Account
Joined 2005
My latest D2KNeo
Thru hole
hi all busy perfecting smps and ucd semi discreet .that is lm 311 and ir2110 in ucd amp. all is well the amp is o.k and cool even at 2 ohms :cool: but ocp protections are the ones holding me back .i have made lorylaci ucd version with protection ,it works well but trips very soon / early. i think when the amp is 60% loud . :mad:
i wanted it to reach about 92% at 2ohm per channel because i wanted to use full bridge +/-70vlts fets used are a pair of irfb4227 per channel:confused: any help some one??.:confused: the schematic ic below and my layouts are below.
I'm can't help, but maybe you can help me. I need the Ir2110 part in Eagle library format. I apparently can't build parts using the free version I have. At least I think that's the hold up. Many functions are dumbed down.
Disabled Account
Joined 2005
Try reduce your current sensor sensitivity by reduce R18.
Maybe half of it or more.
I have something faster if you like.
I make this as I am not happy with the output of two legs of resistor under LTP :D
ltspice file is attached in the PDF also.
Good afternoon kartino The resistor r31 is burning very fast and does not oscillate the amplifier can help me. And I think the "q4" should not be grounded. View attachment class d 4r1000.BMP
I recently finished my audio smps. With 2 irfp460 I had 1kw in test with resistive load. With 4 irfp460 2kw 5min same test. Big toroidal transformer. 50khz. Why many people say 600w with 2 irfp460 is the limit?
Apex d200 is the best quality and stability. I took the principle of d200 I added a fast protection i use irfp250n 100ohm gate m ur1560 parallel to each mosfet 30uh big toroid sendust core. For 74hc00n i use 4 inverter not 2 to increase dead time. 10k 2w resistor serie 5.6v zener. 7812 extra bias 12v. And it works wonderfully with + -95v 4ohm load resistive 50hz frequency. Sound is very good. frequency is 200khz
congrats protech , any photos ?? how long is your amp been operational?? please share your schematic with the modified inverter
