Hi Hadi,
4 PIN connector is BAL IN and it is not used for bridge connection.
another one near +75v is for heat sink to ground (10 ohm SMD & 1nF/100V)
use 1mm (mica/silica or any heat conductive & insulator) space between MOSFET and Heatsink to reduce EMI.
ETD29 1mm gap all. for 250KHz fsw L= (50uH or 70uH)C= 1.5uF
winding 36T 0.5mm x2 SWG wire or 40T 0.5mm x2 SWG wire
MANOJ
MANOJ
i do not underestand what are you say.
please say it more clear
thanks
hi hadi,
sorry!!! my mistake for UN BAL input (cold (-)) joined to GND. Hot (+) and GND used for input {you will get signal if connect reverse ie. cold & GND no problem}
MANOJ
thanks to manoj
thanks for replay
you have smd companent in your amp!!!!!!!!
can you please share part list?
how can i underestand my source is un balance or balance?
i want conect your amp to my car cd player
may car cd player model is pioneer 7150
it is balance or not?
if i have a balance source how can i wireing?
if i have a unbalance source how can i wireing?
i dont know what you said about balance.
i am sorry but i am amator
i am not electronik enginier but i love it and i am new in electronik
i am a attorney in english
thanks friend
Hi sir manojhi hadi,
MANOJ
thanks for replay
thanks friend
Hi sir manoj
thanks for replay
Hi Hadi,
Only two components i used SMD(10 Ohm & 2.2MOhm) both you can ignore (optional)
Consumer product always use UN balance mode (in & out).Only professional Product is used balanced mode.their input and out put is set to @1.3v pp signal level (+4dB)."In balanced working, the signal's positive-polarity connection (+, or hot) and negative-polarity connection (-, or cold) are segregated so that the - is no longer combined with the earth, shield, or ground line. Instead, a three-wire connection gives the ground line its own separate identity. The opposite-polarity + and - signal lines may then be said to be balanced, or set equal with respect to the ground. This balance is engineered, not for aesthetic or philosophical reasons, but so that the next input in the chain can be arranged just to look at the difference between the two audio lines. Every proper balanced input operates as a differential circuit, and any unwanted noise, hum, or interference common to both lines is therefore canceled".
your Pioneer 7150 signal output is UN-balanced one.i think you work for a car amp like SUB WOOFER AMP is it???
if ans. is YES then you need a DC to DC converter for my amp AUD600 and SUB filter.
for 300W 2ohm sub speaker for CAR (small room area) square root 300*2 = 25V supply
so you wire up DC to DC +25v -25V 15A one.
MANOJ
thanks to manoj
answer is yes
i creat it for my car
i dont have + - 25 volt 15A DC to DC converter
do you have any idea about converter
i am ready to creat that
i use pt2322 ic for sub filter and micro AVR atmega64 for control it
(that project is in progres and not complet now)
my sab woofer model is 305c from pioneer company.
thats so good
i have one JBL sub woofer too
it have two magnet 700w 6ohm RMS and it is 12 inch
please help me to creat this things
is AUD600 have short circute protection?
thanks friend
https://anonfiles.com/file/ae83c0e56303c580d483f69e94229f9d
Hi manojHi Hadi,
MANOJ
answer is yes
thats so good
thanks friend
Hi Hadi,is AUD600 have short circute protection?
Yes. short circuit / over current and DC protection you can add over temp. protection also.
PT2322 is not a sub filter it is a 6 ch volume controller with tone.are you building a home theater ???
your IC is not bad for home theater. i prefer SPDIF(digital in ) only. they can handle AC3/DTS signal directly.
DC to DC schematic and PCB i will give to you, pls give me little more time
MANOJ
thanks to manoj
how can i creat over temp protection?
i dont use pereamp or crosse over. i just use PT2322 tone control for 5 chanel amp. what you say? is it enoufe to me or i must use pereamp?
i build it for my own car in home
do you have beter IC like 6 chanell controlabel ecolayser like pioneer car player? it must control by micro controler
can you offer to me a beter IC?
my car player dont have digital exit and i can not use it beacuse i dont have any knowleg about digital sound
sorry for my bad english friends
thanks to all
have a nice day
HI my friendHi Hadi,
MANOJ
thanks to all
have a nice day
thanks to manoj
ETD59?
ETD44?
is EE core beter than ETD core?
how many power (watt) ETD49 can handell?Hi andrew,
EPCOS ETD49 is better than torroid core
MANOJ
ETD59?
ETD44?
HI my friend
hi hadi,
use with any thermal switch 75 or 80 deg. min 1A one
MANOJ
thanks to manoj
Hi my good friend
thanks for your reaply but i dont know hove can i use that
i mean hove can control amp with this thermal switch
were i must conect it?
in input section for cut input signal?
i am wating for your power full DC 2 DC converter
thanks so much
hi hadi,
MANOJ
Hi my good friend
thanks so much
Hi Manojtm
greetings why 1AMPERE if 12 volt operated dc protector is used the positive 12 volt should be in series with the thermal switch going to dc protector relay when thermal switch activates at 75deg power to relay is cut off and amp shuts down as the temprature reduces relay will be energised
warm regards
andrew lebon
Hi Manojtm
warm regards
andrew lebon
hi hadig
greetings,
use thermal diode to sense temp with microprocessor. if sence over temp. send command to mute all channel.
hi hadigho,HI my friend
thanks to all
have a nice day
greetings,
thanks
i am useing LM35 for invironment temp and show in lcd and first time turn on fans and in second time turn off the swiching board.
every chanels have owen thermal control
i want to turn of and on chanel by chanel with every owen amp temp sensor not by micro
i dont want turn off all divaces beacuse sub amp is hot
thanks for your helping and sorry for my english
have nice time for all and cpx
- Class D
- UCD 25 watts to 1200 watts using 2 mosfets
