We’ve kinda been off topic with this stuff on the other dac threads so figured moving it would be a good idea?
Nobody seems interested in moving out of the of the other one,
but I’m sure as soon as I say something stupid they’ll flock like flies!
So Richard as someone experienced in dsp do you think it would be beneficial to make a all in one say 6 channel dac/xo in a preamp style unit? Digital inputs
Stand alone app based/real time dsp controls with separate gain each channel/and a master volume control (all digital) to 3 pairs of decent chips (like the new 4499) or is that 8 channel already?
choice of balanced or rca out.
Full user controlled dsp for each channel/in app,real time .....including lp/hp, slope, delay, phase control, EQ each pair of channels could have a applicable range if that would make engineering easier. Something like Dirac could be implemented but must override able (to tweak afterwards) and bypass able (to be able to compare on/off)
Throw a streamer in/Roon endpoint.
My system is based around a miniDSP 4x10HD, which covers your want list pretty well:
8 channels (4 per side)
AES-EBU, Toslink and coaxial SPDIF inputs + analog input
Single ended and balanced output. I'm using all balanced outputs which are via Phoenix connectors, workable but not terribly convenient.
Master volume control with infrared remote control
Real-time DSP control of level, slopes, xover points, parametric EQ, delay for each channel, plus global parametric EQ for each input channel (separate EQ for digital vs analog input). Each EQ filter can be set up as an externally-calculated biquad, to do things like a Linkwitz transform that the graphic interface can't handle.
What's missing? There is no direct USB input or built in streamer (USB is used for programming only). Programming support is Windows only, no native Mac or Linux software. No FIR filters. No Dirac. None of those things bother me, but for others I'm sure they are showstoppers. As to the quality of the DACs used I defer to someone with greater expertise:
Review: MiniDSP 4x10HD – Neurochrome
As a streamer I use a Raspberry PI with a HiFi Berry Digi+ hat running moOde for streaming FLAC files and internet radio via coaxial SPDIF. Other sources (e.g. Amazon Music, YouTube) stream from my PC via the toslink output of a Topping D10 DAC. The analog input lets me play the odd LP, and is used for TV sound.
I'm sure a better unit could be designed, but I'm not sure I would want to pay what it would cost, and I still have plenty to learn by playing with what I have.
Bill
Bill
thanks Bill,
yah, been thinking hard about the SHD/Studio
but they're only 4 channel, It'd be nice if they offered a upgraded version with 4.2
I suppose unless one is independently wealthy 'compromise' is a fundamental!
Yes I’ve seen that indiglo, do you have one or experience with one? In theory it looks good.
Looks as though it never really took off......prices look awesome but everything says ‘backordered’ ?
No I don't have one or nor have any experience, but it's been in development for 5 years and into its second revision, that could be a good or bad thing depending on your perspective.
I’ll read the whole thread this morning and see if it seems viable.......looks risky at first glance.
They do say ‘no risk, no gain’ though!
Then you need this DDRC-88D All Digital Digital Room Correction powered by Dirac Live
Nah he just used a std MiniDSP. Although in his last months he went back and improved his analog crossover and decided that was better after all. The one I linked lacks the streamer, but has 8 digital outputs (so you can pick and mix you DACs if you want) but has the fancy FIR processing. BUT you are starting to get to a point where maybe a PC running it all starts to make sense depending on the use case.
Yah the ddrc8 needs a computer to run it too.
Roon core or SGC core is a possibility also
Looks like the ddrc8 goes up to 192 sampling so that’s good.......might be the least expensive way to go.
I’ve already got a good streamer to tie into it so that’s a bonus.
Hi Bob,Nobody seems interested in moving out of the of the other one,
Your spec reminds me of DEQX. Do you have them on your Radar? May be worthwhile 😎
Greetings,
Winfried
Bob, you are looking for a DSP solution to play around with, is that right? Or else, what is your goal?
Goal is to assemble the best version (that I can) of a 2.2 (two ways+two subs) tri amped, full dsp/xo and real time user control.....I kinda like the idea of FIR in that ddrc8, seems to give the most versatility for the money.
Winfried,I’ve looked at the deqx and is indeed on the radar but I think it’s at the upper, upper end of my budget.
Bill, That’s cool ....midi was all the rage awhile back.
I have not tried them yet but I have a pair of Behringer Super-X PRO to try.
I too am looking for a high enough performing X-over. I dont want to have to design and build one myself.
So, it needs to be off-the-shelf.
-Richard
-Richard
It'll be cool if I can get it to work! The plan is to be able to adjust settings whilst sitting in the listening chair. bending forwards to adjust on the laptop is not a good way to get consistency!
- Member Areas
- The Lounge
- Tying subjective listening with objective measures/ sound perception/ and DSP
