So I did it for Vifa-Mirage 5DR51441 tweeter and it sounds so good.
It is much a better solution than L-pad.
I put Zobel circuit to one woofer Visaton W250S (22uF+8R2) and it rolls off higher frequecies significantly.
I can´t tell if it´s better or worse, but the sound is different.
The "spark" in the sound of the woofer has diminished.
Yes, I know, but I didn´t expect such a change.
I´m listening to Holiday /Scorpions/ and the guitar in the beginning can be heard just in one woofer now 🙂
If there isn't one, what is causing the change in response? The RC circuit will have near to no effect against the amplifier alone (assuming it is a typical amp).
- Tweeter Q change with series resistor for attenuation?
