Tubelab SSE part numbers
I live in the UK so Edcor is not an option for me unfortunately. I already emailed them and was told that they cannot ship here. TME might be good though. I am planning to use 6L6GC tubes first. Thanks
The Toroidy TTG-EL84SE (around £65 from TME before shipping and tax) with 5k primary will probably work best for the 6L6GC. This transformer is rated for ~150 ma primary current, so do not let the EL84 reference discourage you. I have not used this particular SE transformer, but friends achieved fine results at 20 watts with the Toroidy TTG-KT88SE transformers (3K primary) in sweep tube SEs (Tubelabs’ UNSET).
See https://www.tme.eu/en/details/ttg-el84se/toroidal-transformers/toroidy/
Great, thanks a lot Francois for the details.
I suggest that you contact the people at TME by email or phone, and enquire about selling you some transformers. I hope it is online ordering only that is still a Brexit casualty.
As per the latest they only sell to business customers in the UK. So probably it's best to look for a local source.
Primary Windings seems to be a good option. Could someone just confirm if these transformers can be used please:
https://primarywindings.com/product/pwht11/
My only concern with this is that the filament windings are not exactly what George recommended - main filament only up to 4A not 5A and the rectifier filament is 6.3V not 5V. I don't mind if the B+ will be closer to 400V than 450V.
https://primarywindings.com/product/amp-maker-15w-single-ended-output-transformer/
I think this OT might be a replacement of the 125ESE what wdecho advised earlier.
Can you guys see any issue with the OT's mounted 45° rotated? I am just wondering if it might cause any additional interference with the power transformer?
If mounted vertically, the fixing bolts would be under the PCB, very close to B+ which makes me feel a bit uncomfortable.
