Possible, mine is 16 X 13 X 3 custom built. The height is good, 3".OK, thanks. I might give a go with these then. What size of chassis did you use? Would be a 12x10x3 big enough for mounting them inside?
Perfect, thanks. I will double check the layout with the exact footprint.Possible, mine is 16 X 13 X 3 custom built. The height is good, 3".
The Toroidy TTG-EL84SE (around £65 from TME before shipping and tax) with 5k primary will probably work best for the 6L6GC. This transformer is rated for ~150 ma primary current, so do not let the EL84 reference discourage you. I have not used this particular SE transformer, but friends achieved fine results at 20 watts with the Toroidy TTG-KT88SE transformers (3K primary) in sweep tube SEs (Tubelabs’ UNSET).I live in the UK so Edcor is not an option for me unfortunately. I already emailed them and was told that they cannot ship here. TME might be good though. I am planning to use 6L6GC tubes first. Thanks
See https://www.tme.eu/en/details/ttg-el84se/toroidal-transformers/toroidy/
Great, thanks a lot Francois for the details.The Toroidy TTG-EL84SE (around £65 from TME before shipping and tax) with 5k primary will probably work best for the 6L6GC. This transformer is rated for ~150 ma primary current, so do not let the EL84 reference discourage you. I have not used this particular SE transformer, but friends achieved fine results at 20 watts with the Toroidy TTG-KT88SE transformers (3K primary) in sweep tube SEs (Tubelabs’ UNSET).
"We would like to inform that due to Brexit, registration for individual customers from the United Kingdom has been temporarily suspended." by TME
Blimey!
I suggest that you contact the people at TME by email or phone, and enquire about selling you some transformers. I hope it is online ordering only that is still a Brexit casualty.
As per the latest they only sell to business customers in the UK. So probably it's best to look for a local source.I suggest that you contact the people at TME by email or phone, and enquire about selling you some transformers. I hope it is online ordering only that is still a Brexit casualty.
Primary Windings seems to be a good option. Could someone just confirm if these transformers can be used please:
https://primarywindings.com/product/pwht11/
My only concern with this is that the filament windings are not exactly what George recommended - main filament only up to 4A not 5A and the rectifier filament is 6.3V not 5V. I don't mind if the B+ will be closer to 400V than 450V.
https://primarywindings.com/product/amp-maker-15w-single-ended-output-transformer/
I think this OT might be a replacement of the 125ESE what wdecho advised earlier.
Thanks stenak, but they don't ship to the UK.Check Don Audio in Germany
I decided to give a go to the Amp Maker 15W OT from Primary Windings. They are very similar to the 125ESE, but 3K primary.
Can you guys see any issue with the OT's mounted 45° rotated? I am just wondering if it might cause any additional interference with the power transformer?
If mounted vertically, the fixing bolts would be under the PCB, very close to B+ which makes me feel a bit uncomfortable.
- Tubes / Valves
- Tubelab SSE part numbers
