I am using auduo test for power supply capacitors. I listen to them making their own sound (capacitor to the ear) and passing sound to good quality headphones. Motor run capacitors are not all the same. The newer ones (metallized polypropylene vegetable oil) may indeed sound terrible, but the older ones may be quite good. The best of all are antique paper in oil with foil electrodes.
I believe that the way to improving current capability of power supply is oversized transformer, swinging choke, and low DCR components, not increasing the size of capacitor bank.
Andy, if you don't need to try the large-cap solution for bass, you can forget the electrolytics. But I would expect gains if you use better MKPs at the OT end, and the same, or the DC Link at the rectifier
Any advantage in FKP film/foil over MKP metallised polypropylene?
Oh, for the religiously resolute, there will likely be resounding rebuttals about how little The Goat knows about anything rectification-and-filtering oriented in power supplies. Whatever! My life's experiences tell otherwise.
⋅-⋅-⋅ Just saying, ⋅-⋅-⋅
⋅-=≡ GoatGuy ✓ ≡=-⋅
I agree, unless faulty a rectifier has no sound.
I built a valve mixer with 1n4xxx series and the switching spikes were very noisy. Changed to Schottky and problem went away.
A designed-for-audio film cap should really be best, if you can stand the size and cost.
But the cheaper MKPs made for motor applications can be very unpleasant.
Add yet another "player" to the PSU filter cap. roster. DC link caps. have drawn their fair share of favorable "press".
FWIW, I view with favor using a DC link part in the 1st position of a CLC filter that's being employed in an engineering change from vacuum to SS rectification. FWIW, I have something like this in mind for the 1st smallish position.
I've used the Panasonics that Eli linked. Is that type generally referred to as DC Link, regardless of brand? Or is DC Link a specific brand?Andy, if you don't need to try the large-cap solution for bass, you can forget the electrolytics.
I've heard people mention MKP and I always assumed that they were referring to a series of caps made by Wima, which are labelled MKP. But your comments make it seem like it refers to type of construction, perhaps metallized polyester?
I have some Wima FKP types, which I believe are polypropylene film and foil types but, again, I thought the designation referred to a series of Wima caps.
What's the difference between the MKPs, the DC Link types and the Panasonics Eli linked?
I have no way of measuring but the Panasonics seem to work well and they are reasonably priced, although they are about 4x more than a similar Nichicon electrolytic. They are larger, of course, and more difficult to mount.
I have no idea what they were "designed for" or how they're constructed, though I assume they're not considered "audio caps". If they were they'd be labelled with metallic gold script and cost much more.🙄
I understand that the temp rating of electrolytics is, in itself, not critical but I've always figured that the hour rating (10,000 hours or more) should be a good indicator of general quality and reliability. Caps with those specs also seem to have other specs, like ESR, that are pretty decent.Concerns over lifetime have little to do with risk of outright failures. Rather, it is the fact that the caps degrade, even if unused. high quality parts with pH-neutral electrolytes degrade much slower, and their performance stays stable for longer.
Although electrolytics don't like heat, the self-heating is usually low in valve designs, and more so if a low ESR part is selected. In this case, the extra cost of 105 °C parts does not achieve anything, in typical amp designs - it is better to spend this extra on choosing from a better range with an 85 °C rating.
I like the ALC/ALS range personally, but there may well be others. See if the vendor will tell you anything about how long you can store the part before the leakage current will typically exceed its rating.
Thanks for suggesting the ALC/ALS caps. Digi-Key lists them with the cheapest (and lowest value, 330uf) being about $12, which is the about the same as a 50uf Panasonic film. I rarely use anything over 100uf, though, and it looks like 330uf is the lowest size they stock.
Other than the obvious difference in capacity, how do you think they compare with the Panasonic film?
Are those of you who use SS rectification unconcerned about inrush current and the possibility that the tube plates will be hit with significant voltage before the heaters have a chance to fire up?
I know thermistors can be used but my impression is that they are of limited value. Better than nothing but probably no more effective (perhaps even just a bit less) than a directly heated tube rectifier and much less effective than an indirectly heated tube rectifier. Maybe I'm misinformed about their relative effectiveness?
I sometimes use a thermistor on the primary to help ease the inrush current to the heater winding, even though the amp is tube rectified.
Again, it seems to me that an indirectly heated tube rectifier would be the best choice for a preamp or lower power SE amp where the current is more stable than a high powered PP amp.
Until you get above 500 V., cathode stripping is of minimal concern. Also, the slight delay provided by a well selected NTC inrush current limiting thermistor in the PSU filter wiring is sufficient, when an "instantaneous" on, SS rectified, C- (bias) supply is employed. The negative voltage applied to the O/P tube(s)' control grid(s) electrostatically shields the cathode(s), before B+ "rises".
That's good to know. Is cathode stripping the only concern when the B+ comes up before the heaters? For some reason I thought there were other issues.Until you get above 500 V., cathode stripping is of minimal concern. Also, the slight delay provided by a well selected NTC inrush current limiting thermistor in the PSU filter wiring is sufficient, when an "instantaneous" on, SS rectified, C- (bias) supply is employed. The negative voltage applied to the O/P tube(s)' control grid(s) electrostatically shields the cathode(s), before B+ "rises".
So, if a SS rectified bias supply is powered from the same PT as the B+, the correct placement of a thermistor would be on the center tap of the HT supply, not on the primary so that the C- is unaffected. Correct? I suppose the filament windings would also get their own thermistors on the secondary side too.
I've been using battery grid bias on some builds and the battery is not switched so there is always negative voltage on the grids, even when the amp or preamp is turned off. Is that a problem? If not, does that mean it would be best to put the thermistor on the primary where they are more typically used?
Stage amps have an "on" switch and a "standby" switch for the HT.
Pretty simple solution. Useful for mesh rectifiers as well since they can spark if they're not warmed up.
I look at it this way. Tons of tube gear has been made with silicon diodes and no b+ delay. You'll see it even on luxury brands like McIntosh.
> Tube rectifiers have an internal resistance that will cause loss of supply stiffness, and since the capacitors cannot be large on a tube rectifier, the B+ voltage bounces with the music, which may impart a characteristic sound to it.
I wanted to look into this for my 300B-SE. Partly because of the lack of supply stiffness, and partly because of the relatively poor stability, lifetime, and sound of smaller high-voltage consumer-grade electrolytic caps.
My 300B-SE uses the oversized Sowter SA-08S (OT spec: 25W@20Hz, 0.5% THD), that allows much better bass than standard OTs for 300B.
SA08 SINGLE ENDED OUTPUT TRANSFORMER
With this OT, the 300B's internal anode-resistance of <800Ω would be better fed from a supply with bigger cap than even damper diodes can support.
A few years ago the Kemet ALS61 series caps were on sale for a low price, and I built a new supply based around the ALS61 550V 820µF parts. This means a reactance of near 10Ω at 20Hz - that's better.
The ALS & ALC series were acquired from BHC, and I know of these from designing them into professional equipment. They have a lifetime of well over 10000 hours at moderate temperatures, and the electrolyte has a neutral pH, so they do not degrade or need re-forming with anything like the same speed that consumer electrolytics do. Not to mention that 550V is able to withstand no-load conditions for many anode supply set-ups.
I built the supply with rectifiers in a bridge:
Wolfspeed C4D02120A, SiC Schottky Diode, 1200V 10A, 2-pin TO-220
the ramp-up current pulses are still a bit marginal for these, so the supply was run with a 35Ω-loop (including PT resistance), and little clip-on heatsinks for each diode (these need some mass, rather than surface area, since the real stress is at start-up). I used a cap-multiplier to give a slow rise-time, similar to damper diodes, to further reduce the initial diode-heat, and because I don't like abrupt application of HV to any circuit.
Now the supply looks like:
SiC Bridge → 27Ω [20W wirewound] → 820µF/550V → Cap-multiplier → 820µF/550V → small L → 100µF Audio MKP → PT.
This supply has been running for over five years, without problems, and with excellent consistency of sound. I don't believe it loses anything, compared to the polar opposite previous design: choke-input using a huge oil-filled 14H choke (from the Bletchley Park radio rally) , 6CJ3 dampers and LC stage filtering. It can play any kind of music, including pounding club 12" plates (that cause 300B-SEs to usually sound merely flatulant) - though mostly it plays symphonies.
Sound-wise I don't have a very definite preference, but I will say that using high-quality 550V ALS (now, choose ALC10 series) caps gives confidence that the sound is consistent over time that 47-100µF consumer caps do not give; but it seems that the ALC10 series is now available all the way down to 68µF (ALC10A680BC550) if you want to investigate these on a damper set-up.
The Bletchley Park radio rally!?!? That sounds like fun! 😀
When unswitched battery grid bias is employed, electrostatic protection of the cathode is always present.
Power should be applied to heaters immediately. Get emission going. If you want heater thermistors, use a separate filament trafo that's energized before the rectifier feed is energized.
In a FWCT or bridge setup, the place for the thermistor is in the "hot" line, between the rectifiers and the PSU filter. In a "full wave" doubler PSU, use twin thermistors as shown in "El Cheapo" or a single thermistor in the line between power trafo and doubler cap. stack junction.
I thought the main issues with tube rectifiers were:
* large voltage drop / sag
* didn’t like driving large capacitance smoothing caps.
The slow start can be nonthermistor emulated with a Dirac/triac, or simply use he LT3080 and/or LT3081 soft start. With heaters you can parallel LT3080s for current and get a steady voltage with soft start, if you want corrent limiting then simply add a LT3081 after it and set the Ilim pin.
... or simply use he LT3080 and/or LT3081 soft start
How exactly do you use a 35V LDO voltage regulator to soft start a 500V power supply?
I’ve never seen a soft start circuit like that for heaters before. I can hardly believe this could be necessary. Never used it either.
Regards, Gerrit
Regards, Gerrit
21st Century Maida Regulator
LOL... Nick, you need to express yourself a little more clearly and honestly.
In #54 you said you can get soft start by "simply using the LT3080".
Tom's regulator is a very nice piece and I own a couple myself. But to call that "simply using the LT3080" and using it as a soft start when you don't need regulation is absurd. And in most situations you don't want to regulate B+, just the screens.
Ahh you didn't say all that 😉 😛
It's very clear with SS vs Tube, from my humble playing during research with modelling, is just how hard SS starts are compared to ye-olde tubes. One interesting concern that Carlson (Carlsons Lab YouTube channel) demonstrated is the impact on heater failure rates on some of the less reliable euro-tubes with SS power.
Yeah, I have a few vintage pieces that use SS rectification with no delay and I've never really worried about it much. But thermistors are cheap and they certainly have benefits. So when I'm restoring something I often add them.I look at it this way. Tons of tube gear has been made with silicon diodes and no b+ delay. You'll see it even on luxury brands like McIntosh.
Voltage drop varies but it's no big deal. Just take it into account when the PS is designed and you'll end up with the B+ you need. And, interestingly, indirectly heated rectifiers that provide a slow start typically drop less than directly heated ones.I thought the main issues with tube rectifiers were:
Sag, as I understand it, is more of an issue evident in PP amps, especially if they're run hard. Current doesn't vary nearly as much in a preamp or SE amp.
The cap size limitations apply to the first cap in an C input filter. Subsequent caps can be large, which helps deal with sag issues if the amp has them. And it's easy enough to add an extra RC or LC if sag is still a concern. Of course, choke input filters can also be used.
I'm totally ignorant about all the SS devices that seem to be so popular with so many people here on the "Tube" forum. So I don't know how they compare in terms of their ability to slow the startup. I know that indirectly heated tube rectifiers are simple and provide a slow gentle startup.
Yeah, not really necessary - if it was then you would see lots of heaters burning out.I’ve never seen a soft start circuit like that for heaters before. I can hardly believe this could be necessary. Never used it either.
But take a look at the failure mode of an incandescent light bulb. The only time they seem to fail is when they're first turned on, and if you have them on a dimmer, they last much longer. Obviously, their filaments are much thinner and more fragile than those found in tubes, which is why they emit so much light and a tube's filament only glows dimly.
So, while it may not be absolutely necessary, a slower start will reduce the chances of failure. If you're using tubes that are either more vulnerable or rare and expensive, it's a little added insurance. And easily implemented using a cheap thermistor. No need for complex circuitry.
- Tubes / Valves
- Tube rectifier versus 1200v SIC diodes?
