I think he mentions the R I/V because he spoke from "loading the output by resistor 39 Ohms to pull the output to current mode".
Danka!
Has anyone found another transformer source? Hate to pay $25 shipping for a $23 product!
I got my transformer from Antek-Inc, just call them and tell them you want the 9v winding instead of the 6v. It's 5$ extra.
Hi Oliver, I noticed you are using Wago Terminals for this and the Lightspeed board, how do you insert the wire into the terminal? Do you need to buy the Wago tool to get it working?
By the way, here is a cheap source for the terminals:
http://cgi.ebay.com/socket-receptac...emQQptZLH_DefaultDomain_0?hash=item5884298fd6
socket receptacle connectors wago 236 4 pin,wd3,3a 10 p - eBay (item 380174438358 end time Apr-02-10 19:46:32 PDT)
Hi toufu,
with the wago tool it is much easier but you could also use a small screwdriver.
Therefor you must push inside the back hole of the terminal to lift the internal contact.
Best regards,
Oliver
Thanks for all the help, Oliver! I got my board working with the buffalo 2 DAC. Sounds great, very liquid, clear and nice 3D soundstage.
One thing though, I couldn't get it to work with 6922 tubes, just the 12AX7, but even with the 12AX7 I had to make sure the switch is open. Not sure why, can you comment on that?
Hi toufu,
sure i can
The silkscreen legend is designed for a switch.
On the 12AX7 position the contacts for the heaterswitch are open and on the 6N2P position closed!
So with the 6922 the contacts must be opened.
Witch problems do you have with the 6922?
Oliver
I must correct myself!!!
I took a look in the data of the 6922. It has the same pinout as the 6N2P, so
the contacts of the heaterswitch must be closed.
BTW, give the 6N2P-ER a try. They will outperform the 6922 in every aspect.
Hi Oliver, I don't have any switches of that size, so I got 12AX7 to work by not having any jumper across the three pins. Is that correct? I couldn't get it to work with 12AX7 by having a jumper across the two pins that says '12AX7'.
By the way, can I get 12AT7 or 12AU7's to work without changing the Rk resistor? It's set to 200R right now.
This is correct.
About the Rk value for the 12AT7 or 12TU7 i have no experiences.
Perhaps you could post this question at the http://www.diyaudio.com/forums/tubes-valves/156529-tube-i-zator-srpp-dac-i-v-stage-circuit-discussions.html thread.
- Group Buys
- Tube-I-zator Professional PCB
