The pix of the 6SN7 is in post 102 (this thread).
I have a bunch of 6SN7 tubes so it was a logical choice. It does use the V+ and V- outs of the Buffalo and gives an SE output. I used Oliver's board for the power supplies and the ground plane and as a base for the Amphenol 8 pin tube "test bench". Hard-wired the circuit to that.
I recently replaced the PIO output caps with Mundorf Silver/Oil and a .1μF Russian Teflon. I think this gave the sound more body and punch.
Best
Bob
Thanks Bob, what's the value of the Mundorf you used? And I am assuming you parralle the two caps, right?
Ok. I'm up and running. So far I'm very satisfied.
This is what I have put together:
Analog Device AD1865 DAC End 2
Texas Components TX2575 I/V resistors
6N2P-EV (Russian: 6Н2П-ЕВ) tubes
Mundorf silver/gold - 2,2µF output capacitors
I noticed the regulator gets hot. Is this how it should be?
Also do this output stage switch the phase of the signal?
I am using 2.7μF Mundorf's paralleled (sorry) with .1μF Russian Teflon. I used this first on a Hagerman phono stage and really liked it.
Perfect combination! 😉
If you have an input voltage of 12V, thats normal and ok.
The SRPP stage turns the phase to 180 degrees, equal on both channels.
So it doesn´t matter.
Today i got a pair of ampohm polyester in oil/aluminium foil 2,2µF/630V caps.
Jesus are they huge... 😀 I will test them in my DAC vs. my ClarityCaps MR after burning in.
That's Mundorf value I am using as well, gotta give it a shot, thanks!
So, how do you like your ampohm caps? I have been using the Mundorf silver/gold for some time now. I find them to be a little clinical giving a slightly cold sound. I like my music to be more midrange and not giving to much attention to the top end.
At the moment they have about 100 hrs. burned in. Compared to the Clarity MR i used before,
they have a phenomenal 3D-soundstage, wonderful lower mids and a punchy base.
From my side, buy them as long you could.
The next i will try is to bypass them with some 0,047uF K72 teflon caps. Let´s see...😉
Does someone have a clue on what is the problem with my Tube-I-zator?
I used the Tube-I_Zator twice with the BUF II DAC, I like the sound, but every time I used it for more than 4 hours, there's always this very loud pop/explosion. I know it's not the BUF II because I used it for several days with IVY III without a problem.
The tube that I'm using is 12ax7, with 220Vdc measured voltage at B+. Transformer have four secondary, 150Vac and 6.3Vac., I series connected the two 6.3Vac and had about 13Vdc after the rectifier. Do I got the defective tube?
Joe
Joe
Joe
Hi Joe,
have you adjust the heater voltage to 6,3V at the measuring point on the left side from the heaterswitch?
dvb-projekt; have you adjust the heater voltage to 6 said:Hi Oliver,
I used it at 12.6V maybe that is the reason why. I'll adjust it to 6.3V and will try if that will fix the problem.
Thanks,
Joe
Hi Oliver,
I used it at 12.6V
So the heaters runs at 200%... I hope you don´t damaged your tubes.
If you still have these pops, try to change the tubes to new ones.
Best,
Oliver
Hi Oliver,
The tubes are still working. I will find out tommorow if it will make the loud pop. I'll be recieving the 6n6p soon and I might stick to that due to low gain.
Right now I don't have the switch or jumper, once I replace the tube with 6N6P, do I need to put the jumper on the 6N2P trace side or just leave it open?
Thanks for your help.
Joe
Hi Oliver, are you going to have more boards soon? By the way, would it be possible to make the tube socket holes a bit larger for the sockets with larger leads? Thanks!
Hi toufu,
the next boards are in production, so yes!
I´ll keep your wish about the holes in my mint for a next revision.
Regards,
Oliver
Regards,
Oliver
Hi Oliver,
Thanks for the PCB.
How crucial is the voltage rating on the capacitors in tha anode supply?
Can i use capacitors rated 385 V or 400 V in the 220uf/450V spot?
What about the output capacitors? is 250 V sufficient?
Thanks again,
Pilsern
Thanks for the PCB.
Thanks again,
Pilsern
Hi Pilsern,
i would recommend around 2* B+ (under normal load) for the output caps.
Same to the caps in the anode supply. Than you´re on the absolute save side.
Regards,
Oliver
Regards,
Oliver
Hey,
This board is to do a tube output stage out of a TDA1541 dac ? Can I use it on a Toshiba TC9237BN dac ? how to modify it for that.
Thanks.
Srinath.
Thanks.
Srinath.
Hey,
Yes!
I don´t know this DAC Chip, but why not.
Perhaps someone else can help? 🙄
- Group Buys
- Tube-I-zator Professional PCB
