Interesting that it's run as a triode.
It's run as a pentode with equal voltages on plate and screen grid, wired as a cathode follower. Well, suppressor grid tied there too. 😉
As I said before, another pentodes, like 6J1P, work in such schoolbook arrangement like a charm. You can buy a Ziploc of them for the price of Edamame.
No, it's a triode. The screen does not swing with the cathode.
Does screen swing with cathode in cathode biased stage? When I apply a global negative feedback to cathode of the 1'st pentode in my amp, is it triode connected?
In most amps with a pentode input stage (e.g., Dynaco, Mullard 5-20...), the screen is bypassed to the cathode, not to ground.
So in my amps they are what? They are bypassed to ground. 🙂
Neither to anode, nor to cathode.
How would you call them?
I think if the g2-cathode voltage swing is approximately equal to the plate-cathode or output signal swing, it's going to follow the triode characteristic.
By contrast, a pentode follower would swing g2 with the cathode, much like a cascode or triode ACF would swing the plate with the cathode. I have a sketch of one of these I'd like to try...
I vote "triode".
Oops lots of posts... SY has the pentode version in #44.
I vote "triode".
Let it be a Steerode: between Pentode and Triode Steering. 😀
Hmmm... Sounds tasty! "I use Steerodes in my amp; they sound bright, strong and creamy!" 😀
Think of UL, where the screen swing lies between plate and cathode. Is it pentode or triode?
Still the same Steerode, of course! 😉
(Hmmm... time to correct my Firefox's dictionary.)
Screens bypassed to ground with unbypassed cathodes will produce UL behavior. As plate falls, cathode rises, so G2-K voltage falls, but not as much as A-K.
It doesn't matter if the cathode is driven by something else (like NFB) or itself, cathode voltage is cathode voltage.
Tim
Tim
You know Tim; Steerode sounds better for me than UL. UL is associated with taps in output transformer, while Steerode may be used as a common name that includes UL. 😀
Gentlemen;
does anybody have a schematic of Altec M21D?
Does the mike have some resistors inside, or a tube only?
- Live Sound
- Instruments and Amps
- Tube for high input Z
