• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
TSSA V1.7 mosfet Current feedback amp module
Summersales on tssa v1.8 kit.. Save 20%. This kit containing all but chassis and wire we sell for 480¢ã shipping , normal Price is 600¢ã shipping...
This is one smashing offer! If I remember right, V1.8 is a TSSA V1.7 mark II, right? Still 2 x 40 watt Class A and A/B? That trafo looks like the potted heavyweight (11 pounds) toroidal you had specially built for the TSSA which makes this kit look even more like a bargain to me 🙂
This kit containing all but chassis and wire we sell for 480€ + shipping , normal Price is 600€ + shipping
Hi
What is in the kit exactly
What type of transformer?
Does it come with or need 2 heat sinks?
Whats the difference between the v1.7 and 1.8?
How much to post to Australia 4019?
Thanks.
This Kit contains.
  • 1 x Softstart with iluminated power switch
  • 1 x Powersupply Board with fast recovery diodes and 60.000uF/63V ALC10C153EF063 high grade capacitors
  • 1 x Toroid 500VA, 2x25VAC, Noratel with potted centerhole with low mechanical hum.
  • 2 x TSSA V1.8 with output mosfets and isolationpads.
  • IEC Inlet, fuse drawer, powerswitch
  • 1 x Heatsink SK56 - 100SA
  • 1 x Terminal barrier block 6 pol.
  • 2 x Neutrik RCA connectors
  • 2 x pair of good quality binding post
It will work fine with 1 heatsink if bias is set to 250mA per channel. With 2 heatsink you can go for an bias of 500mA.
An extra heatsink will cost 50€ more. So that this kit will cost 530€ + shipping in summersales (Normal price 663€ + shipping).
For transit to Australia it cost 165€ (I am sorry.... But it is the cheapest i have found)
I have found an cheaper shipping to Australia.. 124€
This Kit contains.
Sonny, May I ask if you could (re)list prices and basic specs for the varous versions of the TSSA (on sale) - when you have time for it. I am especially interested in output in watts for the V2, and if you have a potted trafo from Noratel for that one too and its higher voltage rails. Thanks.
Hi
Thanks.
Hi Awty, Check out this post where Sonny explains a little more about the trafo.
Regarding the difference between V1.7 and V1.8 I think it is only component upgrades, but Sonny will answer that I'm sure. All the best, Per
Sonny, May I ask if you could (re)list prices and basic specs for the varous versions of the TSSA / kits (on sale) - when you have time for it. I am especially interested in output in watts and price for the V2, and if you have a potted trafo from Noratel for the V2 too and its higher voltage rails. I assume V1.8 has the same output as the V1.7. Thanks.
