I got the 800w 48V unit here. $44 including shipping as I recall. There is a pot to adjust voltage and I increased it to 50v.
AliExpress
Thanks. Its interesting that the 800W is not listed in the specs table. Also 1000W is same size and only slightly more expensive than 800W.
Maybe in the future. I am looking into getting these professionally assembled by a factory but that won’t be for a while.
I’m interested in a factory assembled board as well.
Let us know
Mo
Let’s start an assembled board interest list then. Note that BOM cost plus board cost plus assembly cost will make this not an inexpensive built amp. Just a warning that prices, depending on level of interest, might be around $200 to $250 range. Shipping will be USPS first class package tracked and insured. Typically $25 for everywhere outside US, $18CAN, about $8 CONUS.
Fully built TPA3255 Reference Class D amp GB interest list:
Name Qnty. Country
DiyJoe 2 USA
Sorry mate it dies not make economical sense!
I would buy the TI board at USD150 instead
Thanks again and good luck
Mo
No problem. I understand - which is why I never offered it but seems people are interested. There are substantial differences between this board and the TI board. Large high current CoilCraft inductors, post filter feedback (PFFB), layout with short traces from Vdd to supply pins, 2oz copper traces, 2mm thick FRP board, rugged connectors.
This is with 120VAC wall plug powering an 800w (48vdc adjusted to 50v) SMPS (Aliexpress $44 LED PSU), also 20w into 3.3ohm load:
THD to dB - convert percent % to decibels dB percentage voltage % vs per cent converter THD+N total harmonic distortions calculation signal distortion factor attenuation in dB to distortion factor k in percent decibel damping - sengpielaudio Sengpiel
H2: 0.0014% -> -97 dB
H3: 0.00092% -> -100.7 dB
H4: 0.00084% -> -101.5 dB
H5: 0.00062% -> -104.1 dB
Congratulations!
Note the TI's main disadvantage: It has bulky components on either side of the PCB.
Best regards!
Post 103 has zip file of BOM and also link to Mouser shopping cart.
TPA3255 Reference Design Class D Amp GB
I would say count on $200ea minimum. The BOM alone is $135. PCB manufacturing cost, NRE cost for automated assembly and per board assembly cost. The only way the cost is low is if we make 5000 of them
This amp is not about low cost. It can’t compete with $55 AliExpress eBay amps, or even the $75 3e amp.
So don’t look at it as saving money. DIY is about getting a unique and awesome performing piece of tech.
Fully assembled TPA3255 Reference Class D amp Interest List
I just had an accelerated need for a bunch of these amps for an upcoming project.
xrk971 24 units USA
Mordikai 2 units USA
Rtep2007 1 unit CZR
Blossom 1 unit NZ
Grahamgraham 1 unit UK
No, I understand, but everyone has their limits
- Group Buys
- TPA3255 Reference Design Class D Amp GB
