TPA3255 - all about DIY, Discussion, Design etc
You can operate @40V DC with your 3E Audio board yes. I would say 36/40V is a good option. I personnaly won't go more to avoid overheat.
Great.
I am testing a power transformer that I have and after rectifying it it gives me approximately 40V.
I was going to buy an SMPS power supply and use it outside the case, but this idea of an external power supply was bothering me a lot.
Joined 2019
clardes, I’m in agreement with daniboun about the voltage range. I used both a 36V and 48V SMPS with the 3e boards (old and new version of the amp) and 48V just heated the heatsink and output coils to an uncomfortable level. The 36V SMPS is fine and everything only gets moderately warm. I’m driving 6-8 ohm speakers as a reference.
What about 40V versus 4ohms ??
I believe that with load these 40V should drop a little, being optimistic, I believe it drops to 38V.
But supposing it doesn't drop and keep the 40V. Is 40V and 4ohms safe?
Great.
This one in revision 3.3 is great and has a nice ripple ! (LLC + Softstart)
SMPS connex 300RS 36V (up to 40V max) and work fine with any 3E Audio Board and other TPA325X
You can also get a Murata PQ250-36
36V / 250W that is also very good for about 65 euros @ DIGIKEY
about $39 @ Components Store )
PQC250-36, Murata Power Solutions PQC250-36 in Stock available. Buy PQC250-36 with best price at Components-Store.com
Yes, I understood.
But I will use a linear power supply.
Anyway, I saw that I will be safe close to 40V.
I receive 3255 amp the other day. It is the ebay YJ-D01 with the TPA3255.
I have a 400 VA 47V spply.
Out of the box I just don't have much love for the sound. It has the NE5532 pre amps.
I did upgrade to the LME49720NA which did make it sound a fair bit better. I guessting the 5532 might be fake.
The marking on the back are different with the tow opamps. I don't have a good way to tell if the 5532 are fake.
pffb question
Hi there,
Didn't want to start yet another 3255 thread so am posting this Q over here. I'm looking at implementing pffb with my tpa3255 design but am wondering about the following: in a standard single rail setup the outputs float at 1/2Vpp as shown in the image below. My Q is whether I should worry about the dc unbalance over R_fb assuming the output of the opamp buffer sits at GND ?
I have made more progress . This new FFT was made after optimizing zobel network . Instead of one cap and one R I used 3 caps in parallel with 3 R in parallel . THD is 0.00045
Note also the absence of H3
I think that at this point this is the best measured TPA3255 (at 5W , 1Khz , 8R)
  • FFT_5W .pdf
To make this work, you op-amps require +/- supplies.
Thanks, I know, please see below where you will find the opamps use symmetric supplies. The question concerns the 1/2Vpp the tpa3255 outputs are on - typically 25.5V with a Vpp of 51V. Doesn't the dc imbalance between the driving opamp output (0V) and the OUT_X (Vpp/2) mess up the control loop ?
871975d1598796645-tpa3255-diy-discussion-design-etc-pffb-dc-png
