TPA3116D2 Amp
The 1 chip could be for the head phone. And the other chip handles the memory for the volume, and it will limit to a fixed value if the volume is too
high when start up. My guess.
black picture is clearer, it is an input, not a headphone-output
Has anyone done bootstrap snubber mod on the red Y/J 2.0 board? Post pics please. Draw me if you can. Please.
Yes, I was just going to request the very same thing, as I was looking at my red YJ with the Panasonic Oscan mod and thinking it would be a great addition. But the surface mount parts will make it tricky. I know some have done it on other SMD boards, but not the red YJ to my knowledge.
It was my first board TPA3116, and for the current $9.99 price at YJ, it's the steal of the century. Anyone who is in the market for one of those crappy docking stations needs to be educated about this board: even when mated with a pair of cheap speakers like the Pioneer BS-22 or Daytons, this thing will deliver gobs more sound.
looking from tpa3116 chip YJred all topsides from 220nF bootstraps or signaltrace towards inductors above 220nF must be used to attach a 330pf that will be connected to 10 ohm resistor that will be connected to gnd. For 220nF most left side, GND is topside 10nF and 104, you can easily go there. For two most right 220nF the fill between both signaltraces towards inductors is GND, easy too. 2nd from left 220nF has least room but fill up and coming down between middle 2 inductors is GND. looks easiest when using smallest smd available cog and 1/2watt.
There may be neater ways, just my thoughts looking at YJred
Doesn't a rotary encoder and mcu based volume control imply an ADC-DAC in the input chain? This is adding unnecessary stuff to what was a fairly pure analog chain. Probably sounds fine, but I think I like the analog only input.
No. Almost all digital volume controls are analog. In fact, I can't find a single one that is digital. What it does is just to switch between a number of internal fixed resistors just like a stepped attenuator. It is the control that is digital. The signal is just as analog as it would be with a volume potmeter.
Thank you. It is beyond my capabilities.
Maybe a photo or at least a drawing would help?
LOL paint is mmm 2 options for far left and far right, so 6 snubbers in this draw🙂 you need 4🙂 orange = remove red soldermask to clear copper and then solder. grey=soldered smd's together but not to pcb! do not remove soldermask🙂 It is very small area to work with YJred. Maybe both snubbers for middle bootstraps best in middle of board? And side bootstraps far left and far right, you do not want to connect inductor to ground, removing red mask just below inductor soldercontact might be tricky? And bigger in pic than in real?
Nice... Will be very helpful... Thanks! 👌👌
