TPA3116D2 Amp
What antennae, the inductors? I've never had EMI issues with my 3116 boards short of very slight buzzing if input cap leads were really long. We'll see what happens when I fire this one up.
The output inductor leads and unshielded body are transmitting (and a bit of receiving) antennae and the input cap leads are receiving (and a bit of transmitting) antennae ... especially at these high "digital" frequencies.
And you wouldn't necessarily (or typically) hear anything obvious like "buzzing", high audio freqs or "screeching" if you did have EMI EMC RFI issues--you'd have osc, ringing, brief instabilities, etc ... way past the audio bands in the kHz and MHz ... This is 'scope territory and that's why it's hard to DIY.
... remember this is more of a "digital" device (large current switching at 100s of kHz) rather than a usual preamp, amp etc ...
The EMI issue is unfortunate for those whose enjoyment of these amps are affected by it. Perhaps this is why they have not penetrated the retail market.
At any rate this newly modded amp sounds excellent. Best build yet. Clean and clear as spring water, and not even broken in yet. All that's left at this point is to try out an Astron power supply, but otherwise I'm happy and ready to move on to other things.
