Now I have done some listening and experimenting, but I'm not really convinced.. mids and treble a bit flat and sounding a little 'modulated with hiss', and found it a bit thin (but pretty accurate) in the bass. I even had to go back to a amp I know and like to check, and then everything was fine. 15V 3A laptop power brick for supply. Tested on a pair of old modified 8ohm Mission speakers that I know well. Low to medium volume.
I tried some tweaks too. Bypassed the series diode on the supply, added a 6800u 'audio cap' on the supply, replaced the input coupling caps with 6,8u WIMA's, and lastly fed it from a 12V LiPo battery. I think there was some improvement with the battery supply, but still not great to my ears.
Impedance 'mismatch' could explain some extra treble, but I think my hearing hardly reaches that high any more, lucky if I hear much over 10kHz I think.
Any suggestions on what more I should try before I dismiss it..?
purchase advice
Hello to all.
I have just discovered the existence of this thread dedicated to the amp discussed here but it is too big to read in a short time and then I thought to ask you. which are the cards with the best quality / price ratio on the market?
bye thank you .
Hello to all.
bye thank you .
Hello to all.
I really like the white boards, the sound is very impressive. the green ones are in my amps, too.
All this praise, but I did not like it, very strong background hiss.
AIYIMA TPA3116 двухканальный стерео высокой мощности цифровой аудио усилитель мощности доска TPA3116D2 усилители 2*120 Вт Amplificador DIY-in Усилители мощности from Бытовая электроника on AliExpress - 11.11_Double 11_Singles' Day
here is ready an excellent option, shakes my homemade column.2019 Новый Бриз аудио DP1 HiFi 2,1 канальный TPA3116D2 полный цифровой аудио усилитель 50 Вт * 2 + 100 Вт * 1 сабвуфер усилитель Bluetooth 5,0-in Усилители мощности from Бытовая электроника on AliExpress - 11.11_Double 11_Singles' Day
can't embed the image
I have this, and we discussed it recently here in the thread. Hiss was gone with bypassing the potentiometers and op-amp, but I was not happy with the sound quality anyway.
Many things may go wrong when measuring THD with ARTA and soundcard which leads to results much worse than reality.Now I have done some listening and experimenting, but I'm not really convinced.. mids and treble a bit flat and sounding a little 'modulated with hiss', and found it a bit thin (but pretty accurate) in the bass. I even had to go back to a amp I know and like to check, and then everything was fine. 15V 3A laptop power brick for supply. Tested on a pair of old modified 8ohm Mission speakers that I know well. Low to medium volume.
1) THD of TPA3116 measured single ended is one order of magnitue higher than in bridge mode. You should measure bridgemode with a symmetrical input of your soundcard.
2) For best results you have to attenuate the output - consider a resistive symmetric divider in the ballpark of 30dB attenuation
3) For comparision measure THD with and without dummy load. Without dummy load it should read way better - otherwise something is faulty, maybe faked opamps or whatever.
4) When measuring THD with ARTA spectrum analysis, compare the harmonics level H2 and H3 with H1. How many dB are they?
5) post your ARTA spectrum analysis plot here with and without load.
6) In case THD varies irregular vs level, use STEPS to generate a plot of THD vs level at 1kHz and post it here.
12V Battery should not sound better, usually it is less dynamic. If it does, there is something wrong with your other PS.
The higher the voltage, the better the sound, 24V are considered best.
What source do you use? To what amp do you compare "sound"?
Are two of the 4 input caps grounded? (Manual)
hello folks....
was looking for more power for my JBLs (4312s)...
and just discovered the world of class D...
long story short, found on ali "TPA3116 and NE5532P, the power is 100W * 2",
how would be a chain of nobsound 6J2 ----> marantz 2235b (as a pre) ----> TPA3116 ?
or better this TPA3116D2? Yes possibly I'm looking for a whole model with case.
And since i won't be able to read the 1132 discussion pages in the near future, were there some tweaks/mods/tools for this TPA ? Recapping, changing resistors, or else?
I'd really like something in the region 100wpc @8 Ohms, do you find this possible?
in your great and unmatched wisdom, could please give me your opinions?
Thank you very much
Thank you very much
If you need pure, low distortion, real power - it is not possible with the 3116 or 3116D2. Look for TPA 3255.I'd really like something in the region 100wpc @8 Ohms, do you find this possible?....
By the way, is it possible to mod them and use as power amps?
Basically these are all power amps with just an extra potentiometer.By the way, is it possible to mod them and use as power amps?
So leaving it full open and using the pre to set the volume?
Yes, you use the extra potentiometer to set a suitable input sensitivity of the power amp. It may not always be fully open.
Hello guys
Can somebody help me about my TPA3116D2 amp?
YouTube
The problem is exacly like on this video. Please read description of video, there is the problem.
I use 24V 8A power supply.
Have you got a DC power supply with a voltage in-between 5 and 9 V to test it with? The output filter chokes may be the problem.
I tested with 12V 1000mA DC , 16V 500mA DC, 24V 8A DC. That is all I have. I also have 32V 375mA but that is too much.
I use this power supply for 24V. https://www.electracool.com/MED200-24.pdf
- Class D
- TPA3116D2 Amp
