Totally solder-less amplifier kits?
Thanks XRK, many good tips here. Will check out the links.
Something similar to the experimental kit is what got me really started on electronics in 1990. I connected a transistor radio, oscillator, and other circuits. Then I soldered together a transistor radio using the circuit from the kit. It worked. I put together a set of speakers.
After my failed (loud buzzing / hum ) amplifier project in 1995 I just gave up until 2015 when my stereo broke down.
Thanks for the recommendation of the JLH. After the antiseptic Lepai type amplifier I bought in 2015 I gave up on commercial amps. I am very wary of buying amp kits. The shipping costs $85 to where I live so maybe that has to wait, but the components are available. Maybe the circuit is available somewhere.
The Weller soldering gun " the Weller D550 heats in just 6 seconds". Let's say that would change my soldering environment..quicker than you can snap fit a wire.
What solder do you recommend?
Another one.
Patrick
That one has the following in the specs:
Tip Temperature 1,100°F - 900°F
This is approximately 480-590, which is too hot IMO for successful soldering of through hole components.
I don't understand why it is so hard to get a simple, normal soldering iron and some 60/40 and practice. Positive airflow to keep the fumes away from your face and happy days.
I only mentioned the monster Weller gun because that’s what I was first introduced to soldering when I was about 6 years old by my father. I was thinking, don’t all DIY dads have this iron?
Nowadays, you can get a variable temp iron that accepts Hakko compatible tips with stand and accessories for $10. I have one of these as a backup “travel” iron and they work very well. Absolutely reliable. Even better than $50 ones.
Mini Soldering Iron Adjustable Temperature Electric Solder Iron Rework Station Mini Handle Heat Pencil Welding Repair Tools 60W|Electric Soldering Irons| - AliExpress
My go-to main iron is now a Weller WE1010NA. Works like a champ and super stable and heats up fast.
https://www.amazon.com/dp/B077JDGY1...abc_QDFXSTXQPSENTEHS130W?_encoding=UTF8&psc=1
If we have a soldering iron and some thick copper wire, P2P amps like this Juma designed F5 is a lot of fun. No PCB needed.
