Tonearm testing
Joined 2014
Been looking around for refences to testing one can do on a tonearm and drawn a blank, so thought time for a thread on it. I have to admit that I'd never really worried about this until I started getting angst over the (very nicely made) stock arm on my KD-550 second turntable. Japanese S-arms with detachable headshells had a bad press in the 90s, so I had always considered it a step below the straight one piece arms that became vogue. Then I inherited the KD-550 when my father gave up vinyl...
So what can one measure, what should one measure, and what can you do about it? My initial thoughts were
1. Bearing friction/cable snagging over operating arc
2. Resonant modes
3. Damping of said modes.
Of these only the resonant modes seems to be covered with the sort of test suite (test record) that we have as you should be able to see anomalies in a frequency sweep. If this is indeed the case then there is the question of where they are occuring to damp them. In a straight tube this should be easy as will effectively be pipe modes, but in a J or S arm with an SME connector at one end it may be a little harder.
For damping you need some sort of chirp test, which isn't on test records so you need to find another stimulus method. I've never seen a waterfall plot for a tonearm, so I assume this is either considered not important or non-trivial.
I've also been looking at accelerometer options but not found anything small enough to tape onto a tube.
Problem I see with that is you are measuring what is going on but not where. Maybe that is all we have to work with.
I also wonder about the modes they show* as I am sure I saw an analysis somewhere on pipe modes that showed that the dominant mode has two maxima along the tube (hence why audiomods put two reinforcing washers in their RB300. As usual I didn't save the link.
*They claim on their graph a main mode of 280Hz but a hoofing great peak at 4x that frequency. I assume they mean 'first mode' in which case the 4th harmonic does matter as per audiomods
Maybe George's accelerometer interface setup would work. I worry about the added mass.
Thanks for the link. Very interesting. Shame they seem to be making the usual errors about compliance, although that is forgivable given the definitions are lost in the mists of time. I shall read, digest and consider.
My compliments, very interesting and at the same time showing how careful one should be to come to conclusions.
Measuring and listening are in many cases leading to different results.
Trying to "fit" the measured- onto the auditory results seems the way to go just until some impossible result knocks the theory completely to the ground.
But very instructive is to read how the design of an arm can largely affect reproduced sound.
Hans
It also shows how much misunderstanding there is about CLD!
But nonetheless a fine starting point for me. Affordable accelerometers is the next challenge. Anyone know if there are Mems setups accurate enough? A 3-axis measurement would be a nice uplift in measurement capability, if only to prove it might not be needed 🙂
It is interesting, and thoughtful, thank you jcarr for bring it to our attention. Adds some fuel to the fire surrounding my current unease with vinyl playback in general, and the fact that we probably understand a good deal less than we think.
I read a couple of entries in the blog, and signed up.
Dave and Bill both know more or less where I'm at. 😀
Me? Surely not 🙂. I just remain amazed that vinyl works at all. Let's face it, if you gave a group of engineers the challenge of retrieving microscoping information from grooves who had never seen a record player they would probably come up with something that looked more like a lathe than what we recognise as turntable.
On the cycle home I was mulling the bearing resonances measured, mainly because it could end up costing me money. The SME damper actually bolts to the bearing housing so it damping at the bearings. This means it could have influence beyond taming the arm/cart resonance. But I doubt anyone has measured that.
I should also note in the ongoing 'do MC put more energy into the arm' debate I have a shure SC35C weighing in for the MM side. 4-5g VTF and 5cu compliance. I bought it as much as anything to see if I could tame it 🙂
Reactions: StevenCrook
Re-reading the articles by Morgan Jones on the making of his tonearms he also needs the 4th mode of the armtube as the potentially problematic one. He had found that a strip of electrical tape around the tonearm at the resonant Maxima was enough to damp things.
As to where these maxima are it appears to be 5th harmonic. as the tube is effectively 'closed' by the bearings. This leads to the question, if you have a townsend style damping trough at the front is that enough to make the armtube appear as a closed pipe? I suspect it might.
I suspect the 'do MC put more energy into the arm' debate is diverting our attention from the real issues. The more accurate question would be "do low compliance cartridges with lots of stylus suspension damping put more energy into the arm"? The only work a 1mg effective mass stylus should be called upon to do is move the active element enough to generate a millivolt or few of signal. It shouldn't be putting any excess energy into the arm at all. I look forward to seeing your experimentation results with the SC35C.
Ray K
I look forward to finding time to complete the groundwork to start this. As you know it is much easier to collect projects than to finish them 🙂. But I have examples of tonearms and cartridges from low compliance and heavy to high compliance and very light. Around a 7:1 ratio between extremes. I am hoping to eventually find out that it doesn't matter as long as you optimise accordingly.
