TL sub project
Time to archive
useful links friends time to archive i explain a little . people who hv the common sense can archive everything thing as the same but difference by time. some friends on here in the group of panna(Intellectual). all of them will spent the time a litle. i know im in the group of Energetic . everything spent a lot of time to learn. but peaple in three groups can archive as the same.🙂
the finished pics 15 tha push pull th.
metro 15 pics paudio 2226 is good for this cab the metro plan i chang the port location from the original plan its because i cant know the answer the hit. the magnet hit port? or the port hit the magnet or both of them hit together. still dont know the problem about this so that i chang the port location.🙂
Brian Steele in the video only use 15 mm wood n built again use 18 mm but cant stop the shaking. cross-bracing is difficult to use in the front so that i use double front panel. n only use cross bracing in the top of this cab🙂
KATL friends i design this cab for kane speaker driver. the driver order from china. the new 12 driver from kane. i suggest him about the ts parameter that i want to use with the tham 12 ok they ordered to factory in china. lots of my friends still waiting....... KA is kane15 ka22 driver.
